spitting grey smoke....help!!!
heres the situation. i have a fully built 2.4l engine with a MIVEC head. it is the 4G64 block and 4G63 head. im running wiesco pistons, eagle rods, GSC 272 cams (both), supertech valves 1mm oversized on both sides and an unorthodox underdrive pully set. in conjuction with all that i have all the supporting bolt ons and a GT35r ball bearing turbo. the problem arrises when i turn the car on. once you rev the engine and let off it spits grey smoke. ive look for everything and the oil pressure is good. could it be that the car just needs to be tuned? please help me out!!
Did your Supertech Valvesprings come with the Viton seals or do they just install stock seals? There was a problem with the Dual Springs from Supertech hitting the stock valve seals and of course causing leaks thats why all of Supertech kits come with Viton seals now.
Chris
Chris
06ravenmr: there is a little oil in that tube, but nothing unusual that i havent seen before.
2k4EvoVIII: all the seals were replace during the head work. but yes they are stock seals. but i have single springs not dual though.
have it checked out tho. dont just waste time and money on seals. it could of been machined wrong. who knows it could be a number of things. if the motor rebuild is fairly new it just might need time for everything to seat wright.
