shep tranny..exedy clutch help
Old Aug 29, 2008 | 06:26 PM
Gbrownn08's Avatar
I got a brand new tranny from shep and clutch with a little under 1000 miles on it..whenever im coming to a stop from say third or forth gear, if I dont blip the throttle its hard to get it out of gear. When it does come out of gear, the car wants to die, the rpms will drop really low (around 500). I'd say 1/3 of the time the car actually does die. I am running 1000cc injectors on stock ecu if that has anything to do with it?
Old Aug 29, 2008 | 06:49 PM
1NASTYIXMR's Avatar
sounds like it might be a vacuum leak
Old Aug 29, 2008 | 06:54 PM
kkarim's Avatar
has your ecu been rescaled for your 1000cc injectors? are you running a VTA bov?
Old Aug 29, 2008 | 07:04 PM
Gbrownn08's Avatar
yeah running tial bov..i have 1000cc injectors but my car wanted them scaled at 650 thats another problem that im trying to figure out
Old Aug 29, 2008 | 07:10 PM
kkarim's Avatar
i have no idea concerning the gear lockout, but i am pretty sure your car wanting to turn off has something to do with your badly tuned/scaled injectors, and the maf being upset by the VTA tial.
Old Aug 29, 2008 | 07:24 PM
KevinD's Avatar
definately stalling from the tial. and injectors scaled improperly will make it worse. if they needed to be scaled to 650cc to get afr correct at idle, sounds like you have a very big boost/vacuum leak.
and the gear lockout is likely due to not having the clutch pedal properly adjusted
Old Aug 29, 2008 | 11:20 PM
Gbrownn08's Avatar
any other help?
Nujntsaimyaj
Apr 26, 2016 03:55 PM
Donkeypuncher
15
Nov 10, 2010 05:34 AM
evodrivesme
24
Aug 14, 2010 05:51 AM
05blue8
Apr 17, 2009 12:43 PM
evo05VIII
13
Mar 6, 2009 03:47 PM
