Cam Install???? Why so expensive
Old Sep 8, 2008 | 09:58 PM
partyboy1122's Avatar
Bring it to MA, I'll do it for you. 30 rack and we will call it a day.
Old Sep 8, 2008 | 10:03 PM
tarmac4g63's Avatar
the evomoto writeup is a great guide simple install i didnt even have to jack the car up
Old Sep 8, 2008 | 10:38 PM
Sr20kidD's Avatar
Originally Posted by srajeremy
there is usually a book that has price quotes of how long it should take and most shops will just charge by the book. not always but its basically like why should a better mechanic get paid less for doing the work quicker. i think its quoted as four hours.
If the shop is ASE certified then they have to play by the rules like all dealerships.
If its a mom and pops shop then good luck. Most "Tuner Shops" are not ASE certified nor do they have ASE certified mechs and are usually gear heads like us that can either do a good job or a ****ty job, some really don't care as long as the car is drivable when it leaves the shop and if it breaks down the road then good luck to you...
Old Sep 8, 2008 | 11:13 PM
vboy425's Avatar
it's not hard, but at the same time it's not easy. It's look easy, but that doesn't mean it is easy. If you mess the timing up, say bye bye to your block.
Old Sep 9, 2008 | 06:26 AM
Ivan@AMS's Avatar
While doing cams is not a super hard job, there are so many things that can go wrong during the install that can cause catastrophic damage to your motor. Aligning the cams wrong just one tooth will make your car run bad, more teeth off and your bending valves. If the balance shaft belt moves, its going to cause a vibration. Improper torque on the cam caps, sensor cups or cam gears and you have problems down the road. Accidentally drop a bolt in the motor... bad news. Drop something in the timing cover... more bad news. Improper break in lube, bad news. Lifters not bled right and the car wont run right. Evo 9 with MIVEC is a whole new animal. I have seen even seasoned mechanics have issues with cam swaps on a 9. There is a lot that can go wrong.
I am not trying to scare anybody into not doing cams themselves, I am just saying that just passing responsibility of the above issues to a trusted shop is worth a lot more than than the cost of labor.
If you are mechanically inclined and have the proper tools, do the swap yourself. If you would rather have someone experienced with the job do the swap, bring it to a dealer, shop or specialist.
AMS charges less than book time for the job and charges less per hour than the local KIA dealer charges.
Old Sep 9, 2008 | 07:22 AM
jmartinez1170's Avatar
Well call adam at devo tuning and call it a day he seems to bang them out in no time less then a hour. If i recall it was like 250 or something like that.
Old Sep 9, 2008 | 07:53 AM
hytek369's Avatar
hey, you are local. i will pm ya.
mirai
Australian Forum
Jul 9, 2014 02:50 AM
bafhoops89
16
Aug 22, 2012 05:30 PM
BaumBizzle
Jun 13, 2012 10:13 AM
1FastT2
Northeast Region
Dec 21, 2011 07:44 AM
Don Q
Nov 6, 2010 07:02 PM
