How much would a shop charge me for...
Old Nov 6, 2010 | 06:25 PM
Don Q's Avatar
Hello,
I need to install cams, springs, retainers, megan o2, ETS IC with IC piping, 1000cc injectors, HKS timming belt, fidanza cam gear and FP RED. I would like to know what should I expect to pay to get this work done by a reputable shop? Thanks in advance!
Old Nov 6, 2010 | 06:26 PM
SLO-EVO's Avatar
Depends on the shop's hourly rate. You won't get a good estimate here because it will vary from shop to shop. Your best bet would be to call Shops directly.
Old Nov 6, 2010 | 06:30 PM
Don Q's Avatar
Hmmm I see... and I'll do that first thing on monday, but I wanted to get an estimate to be prepared or to know what a "fair" deal would be
Old Nov 6, 2010 | 06:32 PM
ElectrIX Blue's Avatar
All shop are different, so its hard to get an answer. Try giving your local shop a call and get a quote. Plus most of your parts are easy to install and can be done in the garage. Also you gain experience by working on your own car.
Old Nov 6, 2010 | 06:42 PM
Don Q's Avatar
I hear you, my only concern is the timming belt, cams and spring/retainers. I would hate to **** up my car
Old Nov 6, 2010 | 06:50 PM
I definitely agree with your there, with the belts and cam i would leave it up to pros.
Old Nov 6, 2010 | 06:53 PM
Don Q's Avatar
Last time I checked, one of the shops told me they would charge me $450 for the springs/retainers job. Guess they would charge about $500 by adding cams, belt and gear... Anyways, I'll see what I can do about the turbo and the IC. Then I'll take the car to the shop for the other part of the job.
Old Nov 6, 2010 | 06:59 PM
EVO IXMR's Avatar
Springs and retainers should cost the most 350 but people usually charge 250.
Old Nov 6, 2010 | 07:00 PM
BenJ's Avatar
You will also need a tune after all is said and done. I would say somewhere in the neighborhood of $1500-$2000 to have it all done. The timing belt and clutch job will set you back the most and then the tune.
Old Nov 6, 2010 | 07:02 PM
BenJ's Avatar
Timing will be the most expensive by far. The parts alone for a timing belt job vary from $400-$800 depending on what you do.
jimmcfeely
Aug 30, 2014 06:00 AM
tevol1
14
Feb 17, 2010 10:30 PM
DynoFlash
Sep 24, 2007 03:24 PM
gaulrich2003
Feb 16, 2006 09:13 AM
LEVIII
11
Apr 13, 2005 11:44 AM
