4g64 W/evo head head gasket
Old Feb 22, 2009 | 06:20 PM
  #31
dsevo's Avatar
Originally Posted by evodave
what do people do for timing... i was told -3.5 degrees both intake and exhaust with evo head on 4g64 block since the deck height throws the timing /cam gears off
Anyone know if this is true? I'm building a 4G64 right now and was wondering about this. Thanks.
Old Feb 22, 2009 | 08:11 PM
  #32
SwiftEVO's Avatar
Either use stock cam gears from a 94?? DOHC Galant with a 4g64 or use evo adjustable timing gears and degree your cams.
--Josh
Old Jan 19, 2012 | 11:18 AM
  #33
VGergo's Avatar
Hello !
I have 87mm bore 4g64 block from a GDI mitsu space wagon and an Evo 9 ported machined head . I would run with OEM headgasket bored to 87mm . I need the Evo 8 OEM 3 layer type ~0.34" thickness.. Did it somebody from that gasket ? Or only the Evo 9 5 layer will work ?
What about the OEM 4g64 gasket ? Do we know the thickness ?
Old Jan 19, 2012 | 02:02 PM
  #34
n2oiroc's Avatar
Originally Posted by VGergo
Hello !
all the modified gaskets that i have seen are evo 9, but it fits the 4g64 block and either the 8 or 9 head. the 8 gasket is thinner, but the 9 is more durable.
Old Jan 19, 2012 | 03:56 PM
  #35
SmurfZilla's Avatar
I had a Power Enterprises on my 2.4. Head lifted a few weeks after we got it running when re-tuning it after running into fuel issues.
I'm on a AMS right now.
Old Jan 21, 2012 | 11:26 PM
  #36
evoyrrah's Avatar
hows the ams holding up so far??
Old Jul 18, 2013 | 10:59 AM
  #37
rick1024's Avatar
^this
i need a new gasket for the 4g64 with mivec head. i emailed buschur and awd motorsports for one and no dice. i know about using the cometic, but after hearing about people having issues, i would rather not take the risk.
someone point me in the right direction please
Old Jul 18, 2013 | 12:42 PM
  #38
evolve_VIII's Avatar
Originally Posted by rick1024
^this
MAP has one.
Also, you can use the felpro gasket for a 2003 Outlander with a 2.4L.
Old Jul 19, 2013 | 03:35 AM
  #39
rick1024's Avatar
can you link me to the map gasket, because i dont see it on their site.
i also never knew you could use the outlanders gasket, that is news to me
bigturboevo03
41
Feb 11, 2017 09:57 PM
4ukc
Oct 10, 2015 11:04 PM
JGNERAEVO9
23
Mar 7, 2014 07:14 PM
Blue91lx
98
Apr 29, 2013 04:07 PM
5LEEPERISAH23I
12
Dec 9, 2010 04:24 PM
