Internal to external WG conversation?
Old Sep 17, 2008 | 11:22 PM
boostdtalon's Avatar
Just wondering if anyone has done this on there evo. I've seen it done on DSM's and know a couple of subie guys that have done this. if you have can you post up some pics. i'm interested to see what this setup would look like on a evo.
Old Sep 18, 2008 | 02:04 AM
kkarim's Avatar
i've heard of wastegate chatter before, but i never knew they could have a conversation... :P
Old Sep 18, 2008 | 02:23 AM
magyar86's Avatar
turbochargers.com has done it before. i dont have pics but i was considering doing that but i ended but getting a whole new kit. they said all they had to do was weld the w.g flap closed then weld a pipe off my header with a flang on it for the new w.g it would pretty much look like a normal external w/g header...
Old Sep 18, 2008 | 05:26 AM
DimitrisIX's Avatar
what would be the advantages of using an external w/g mounted on a stock line mani?
Old Sep 18, 2008 | 07:56 PM
magyar86's Avatar
the only reason i was considering it was because i was having some issues with my w/g actuator and turbochargers.com was going to do the conversion for 250 installed so it was only 120 more than a high psi actuator and you also benifit from open w/g dump and if you ever go to a t3/t4 turbo you will already have your w/g for the new kit...
Old Sep 18, 2008 | 08:13 PM
magyar86's Avatar
double post
Old Sep 18, 2008 | 08:30 PM
Craig King's Avatar
Not worth it. Buy a new high psi w/g.
Old Sep 18, 2008 | 08:37 PM
RevMoto's Avatar
You mean like this?
Old Sep 18, 2008 | 09:05 PM
magyar86's Avatar
its just like buying a open dump o2 housing and a high psi actuator but cheaper...
Old Sep 18, 2008 | 09:06 PM
magyar86's Avatar
Originally Posted by RevMoto
You mean like this?
thats one way to do it but we were just going to put the w/g off the header
Old Sep 18, 2008 | 09:38 PM
RevMoto's Avatar
No it is nothing like buying a dump and a high psi actuator. High PSI actuators really don't work that well. Idk about just welding on to the manifold to one runner. This is a twin scroll. Mine does both sides.
Old Sep 18, 2008 | 10:59 PM
magyar86's Avatar
idk either but they said it worked.
