Clutch problems?!?
Old Sep 19, 2008 | 11:33 PM
Kapoosh1's Avatar
Clutch problems?!?
Went out tonight to do some fun runs. First 2 runs the car wouldn't go in 2nd gear at all. (at the time i blamed myself for not being able to drive). 3rd run I shift kind of slow and everythings fine. 4th I get the 1-2 shift perfect, same with 2-3, but I get completely locked out of 4th! As I give up and slow down I Realize the clutch pedal now feels mushy and won't go in ANY gear and is stuck in neutral.
I get out of the car upset thinking i broke something expensive. My buddy jumped in the car pumped the clutch and slammed into 1st gear. Now the car runs perfect....
Any ideas on what went wrong and how to prevent it from happening again??
Also car is a 06 Evo GSR has a exedy stage 2 clutch with about 8K on it and maybe not so hard 10 launches.
Old Sep 19, 2008 | 11:42 PM
Kapoosh1's Avatar
Also I had new rotors/pads put on today, not sure if that could somehow be related.....
Old Sep 20, 2008 | 09:47 AM
06RedRalli's Avatar
clutch slave cylinder might be takin a dump on ya...same symptoms i had...or ya might have air in your lines...
Old Sep 20, 2008 | 12:23 PM
Duh Panda's Avatar
i have the same issue...... but cant really pin point the problem /:
Old Sep 20, 2008 | 12:30 PM
housedj's Avatar
sounds like you had air in the lines from the brake job. re-bleed your brakes & u should be fine...
cthcky5's Avatar
that happened in my gst...its ur clutch slave cylinder
Old Sep 20, 2008 | 12:46 PM
housedj's Avatar
just rebleed the brakes again & check before u start spending cash on parts u might not need. if u run a Tilton clutch, the slave cylinder is eliminated because of the hydraulic bearing...
Old Sep 21, 2008 | 12:37 PM
Kapoosh1's Avatar
Thanks guys, i'm going to try to re-bleed the brakes today.
Khalid
Dec 26, 2018 01:18 AM
bbong
Jun 11, 2017 05:25 AM
millsyy17
17
Sep 5, 2011 12:22 PM
Dammit Cubs
May 29, 2008 09:09 PM
watchout
Nov 7, 2004 01:31 PM
