Hitting the rev limiter
Old Sep 22, 2008 | 01:53 PM
Ariful's Avatar
I understand the revlimiter is there to protect the engine, hence want to know if its safe to hit the stock rev limit everytime you shift all the way up to the 6th gear. Is it a normal practice, normally i dont do this, i was just curious to know.
Old Sep 22, 2008 | 01:58 PM
ambystom01's Avatar
No, it isn't exactly good for the motor.
Old Sep 22, 2008 | 03:10 PM
def1's Avatar
Well its a lotta stress on the engine but as long as you dont do it everyday all day you should not run into problems. I have my rev limiter set at 8k and have taken it uip there without problems.
Plus redlining it every so often is good to get all that carbon out of your engine
Old Sep 22, 2008 | 05:45 PM
cdupont03's Avatar
Well since it's probably way past the top of your powerband I think it's kinda pointless and dangerous. I would avoid doing so if possible but it happens once in awhile and chances are it wont blow your motor, but the amount of money an engine rebuild cost you might not want to test it.
Old Sep 22, 2008 | 05:55 PM
Smike's Avatar
1) Out of power band.
2) Hitting the rev limiter can happen. Try to avoid, but some autocrosses it has to happen.
WolvieDC
Sep 25, 2014 01:11 PM
Brent_si
Sep 28, 2011 05:23 PM
Noize
30
Jun 13, 2008 06:19 AM
PC325xi
Jan 9, 2008 06:20 PM
SocalES
72
Jan 18, 2007 02:06 PM
