wierd place for boost leak or no?
Old Sep 28, 2008 | 01:30 PM
sharkm87's Avatar
So I decide to do a boost leak test because my WB and 3 bar sensor comes in this week, and i plan to perfect the tune.
first leak i notice is after the IC, the coupler between pipe holding DV and pipe from IC...so i tighten that and I no longer hear whistling....so I pump back up bout 25 psi, and you can see bubbles from the exhaust mani bolt...just one of them.
I guess i can assume air does go threw motor durin the boost test, but didn't think it would flow threw the thread and bolt....anywho, i tightened it down a smidge and the air bubbles there stopped and all appeas well.
i just thought it was wierd to find a "leak" there...that is all
Old Sep 28, 2008 | 01:35 PM
vtec2mivec's Avatar
That doesn't make sense, but as long as you don't have any more leaks...call it good.
Old Sep 28, 2008 | 01:47 PM
sharkm87's Avatar
well, the air still slowly leaked out, but i didn't hear any loud hissing..I assume its escaping threw exhauast at this point..idk, when you guys test is system charged with no leaks at all?
Old Sep 28, 2008 | 01:54 PM
96eclipseGST's Avatar
I know sometimes with blown headgaskets you can push coolent throught the exhaust mani. Thats how people crack them.
Old Sep 28, 2008 | 01:57 PM
sharkm87's Avatar
so are you saying even if the exhaust mani was off, air shouldn't come out at all?
Old Sep 29, 2008 | 09:24 PM
rob17san's Avatar
I dont believe it should. They are meant to seal 100% for emissions etc.
Old Sep 30, 2008 | 03:46 AM
speedypollard's Avatar
do you have an tubular manifold because unless you have ARP Exhaust Studs the stock nuts will back off
Old Sep 30, 2008 | 04:08 AM
sharkm87's Avatar
stock exhaust mani
Old Jun 21, 2009 | 08:17 PM
NsinEvo8's Avatar
Is it still leaking at crankcase/manny? Am having a similar problem
moneyhun89
Sep 16, 2013 03:39 PM
Lgkaos
Jul 3, 2011 04:38 PM
Camrymatic
Jun 10, 2011 06:29 PM
Ted B
Feb 17, 2010 08:52 PM
sharkm87
10
Oct 14, 2008 02:02 PM
