AMS UICP And Mini Battery Questions
Old Sep 29, 2008 | 04:21 PM
LANCEREvo9MR's Avatar
i just recieved ams's uicp and mini battery what should i expect out of the uicp and on the mini battery can i run it if i have a 12 inch subwoofer with a 900 watt amp will everything else work ok or should i stop using it
Old Sep 29, 2008 | 04:59 PM
Andrew@AMS's Avatar
Hey LancerEvo9MR,
Yes, you can continue to use your audio system with no problems with the car running. If the key is on accessory with the engine off then I would not recommend using the stereo system for more than 5 minutes or it will kill the battery. The UICP and small batt. kit will definitely clean up your engine bay!!!
Old Sep 29, 2008 | 05:10 PM
Originally Posted by Andrew@AMS
Hey LancerEvo9MR,
is there any hp gains with uicp, or is that only with the licp combined and do you guys sell jdm xi dv thanks
Old Sep 29, 2008 | 08:17 PM
Bump!!
Old Sep 30, 2008 | 02:49 AM
1NastyMR's Avatar
like he said when the car is on its fine but engine off battery drains fast
Old Sep 30, 2008 | 07:32 AM
Andrew@AMS's Avatar
Hey LancerEvo9MR,
There is a little HP gain with the upper pipe but you will see the biggest gain when you add the lower pipe with it. As far as your other question, not sure what you are talking about ( JDM xi dv )??
Old Sep 30, 2008 | 08:04 AM
TheDream's Avatar
he's probably referring to a stock ix diverter valve
Old Sep 30, 2008 | 08:37 AM
Andrew@AMS's Avatar
Hey LancerEvo9MR,
If you are looking for the Evo 9 BOV we do sell them for 162.37 and we usually have them in stock. Please let me know if you need further information. Good luck with the car!
Old Sep 30, 2008 | 06:30 PM
thanks alot people im getting the licp soon
