Timing Curves for 30psi on pump
Old Sep 29, 2008 | 06:58 PM
AudiA4_20T's Avatar
Anyone have logs of a 30psi pump gas timing curve? Curious, tried to search and couldn't find anything and was just wondering whats a safe number to run up top
Thanks
Old Sep 29, 2008 | 08:41 PM
cfdfireman1's Avatar
When you find out
Thanks
tell us.
Old Sep 30, 2008 | 06:30 AM
donsupreme's Avatar
Bump
Old Sep 30, 2008 | 07:17 AM
crcain's Avatar
I may be wrong but the timing curve for 30 psi will be the same for just about any other boost pressure. I'm speaking of the curve not the actual values of course. The idea of ignition timing is to achieve peak cylinder pressure at the point of best leverage for the rod to act on the crank. When you do this you maximize the power at that boost pressure and rpm. I think this is called something like minimum timing for best torque.
If you run too much advance, you will start to run into knock, or you may simply stop making more power because you are beyond the point of best leverage. On pump gas though, I believe a Evo will almost always knock before you go beyond best leverage (when on boost).
All things being equal, as boost pressure increases, timing must decrease.
As RPM's rise, timing can be adding because everything is happening faster, and therefore, you need to start the combustion process sooner to keep peak cylinder pressure at the same spot.
Peak torque generally means peak cylinder pressure and this is generally equivalent to peak boost. Therefore you will likely run the least amount of timing at peak boost.
In terms of timing it's all about creating peak cylinder pressure at the right point in the power stroke. But if cylinder pressure is too great, then you can start to get detonation. So it is a balance.
Increasing boost pressure yields modest increases in peak cylinder pressure but improves overall cylinder pressure greatly. Greater average cylinder pressure will give you more power than using timing to create greater cylinder pressure peaks. But at some point you will reach the limit of the fuel and adding boost creates just too much average cylinder pressure to make it impossible to get a reasonable timing value at peak boost.
This is how I understand things and I'd love to be corrected by the more knowledgeable on the board.
As for actual timing values at 30 psi on pump, it could be 1 degree at peak boost or it could be 5 degrees or it could be anything. The question is, what boost pressure is yielding the most, safe power. If you know how to monitor the engine properly, and understand what the engine is doing, then you won't worry anymore what timing other people run.
Remember though, altering the head, valves, exhaust manifold, turbo and various other parts will effect what boost pressure you can run safely. So don't be surprised if a fully modified motor can run more boost pressure safely.
Old Sep 30, 2008 | 07:30 AM
warp9's Avatar
Thanks
There are very few who can say they've mastered this sort of tune and I highly doubt that they would divulge that information to you
That being said you would have to push the limits for your specific setup to find out just how much boost vs timing your car can take.
Old Sep 30, 2008 | 07:46 AM
C6C6CH3vo's Avatar
Spark advance does not depend soley on boost so what other people use is useless. It depends on where peak cyl pressure is which depends on afr, boost, cams, bolt ons, plugs. So the only way is to log your car and quit advancing from low timing until it stops making power.
If det threashold is lower (pump) you have to lower something else
Old Sep 30, 2008 | 09:00 AM
SloRice's Avatar
I can't believe someone actually asked that question!!
Old Sep 30, 2008 | 09:13 AM
4kinboost's Avatar
Thanks
I think your question leaves too many variables to be answered correctly.
Old Sep 30, 2008 | 09:44 AM
AudiA4_20T's Avatar
hmm fair enough
Old Sep 30, 2008 | 09:51 AM
crcain's Avatar
It is obviously an uninformed question but I just figure why not discuss the point.
Are you laughing because this is a shock to you people think like the OP? Hmm.. thats odd. As it's pretty clear to me that any typical newbie to tuning would think or ask a similar question.
To the OP... I tried to explain some of the fundamentals of creating an ignition map for a car. You should understand though, every car is different, so it just depends on all the factors explained and some.
Old Sep 30, 2008 | 10:12 AM
SloRice's Avatar
He’s asking about timing curves at 30psi. He can’t be THAT uninformed. If was asking about exhausts or intakes, yes I’d call him a n00b, but he’s not asking a n00b question.
So he asks this question without giving any other details is why I’m laughing.
Stock turbo or 35R or 42R?
Stock motor or built motor?
Stock ECU or standalone?
91 octane or 94 octane?
See what I’m saying??
Old Sep 30, 2008 | 10:17 AM
06MRV8Killer's Avatar
That^
Old Sep 30, 2008 | 11:20 AM
RazorLab's Avatar
Here is timing on a FPgreen Evo 8, 28psi, stock ecu, 91 California octane (straight)
Obviously this does you no good because you don't know the supporting mods, level of porting, AFR, etc
Old Sep 30, 2008 | 11:34 AM
crcain's Avatar
Ahhhh I do understand now. You assumed he is informed enough to know to post more detail. Got it.
Razorlab nice graph there. 28 psi on 91 on a stock frame turbo people. We got a proper tuner here people.
Old Sep 30, 2008 | 11:36 AM
crcain's Avatar
double post! bandwidth shot to hell sorry.
ridenrunwv
Sep 19, 2015 06:42 PM
David Buschur
109
Mar 2, 2011 04:00 PM
PeteyTurbo
GSC Motorsports - Charleston, SC
14
Sep 8, 2008 09:13 PM
SmokinJoe
191
Nov 26, 2006 07:43 PM
DynoFlash
Feb 16, 2005 09:27 PM
