Help diagnosing issue
Old Oct 1, 2008 | 09:21 PM
PWevo's Avatar
I've tried researching what the problem could be for a while now with no luck so far. I noticed that driving on the highway in fourth or fifth gear at 3k rpms, when i'd go wot the car would lunge forward, back off a little, then take off. At first I suspected my bov at the time which was a greddy rs, but since going back to stock ix it still happens. Then I suspected it could be my clutch slipping, but the rpms would not just jump up, the car would move as the rpms went up. I have considered a boost leak, but the car does hold targeted boost. Lastly I suspect it might be due to my megan 02 housing. I've read about the wastegate holes being a little small on some. The problem showed up the last time I had the car on the dyno. Notice how the power jumps, backs down, then climbs back up. Any ideas what could be causing this? I still have a sneaking suspicion it could be the clutch. The pull was done in 4th gear btw.
Old Oct 1, 2008 | 09:25 PM
Billy@EnglishRacing's Avatar
my first guess would be the clutch, take it to a big hill and through it into 5th, see if it free revs
Q@EvoPowerMods's Avatar
Stuck Wastegate Puck......check your WGActuator. take it off and test it by hooking up an air line. I would be willing to bet that it's your WGA.....
Old Oct 1, 2008 | 09:26 PM
PWevo's Avatar
I have tried that on the highway and it doesn't. I've also as someone suggested to me, put the car in 5th at 35mph and punched it and it didn't free rev.
Old Oct 1, 2008 | 09:27 PM
PWevo's Avatar
This happens on the stock wga?
Old Oct 1, 2008 | 09:28 PM
Go find a big hill on a side road and stick it in 5th at about 30
Old Oct 1, 2008 | 09:29 PM
PWevo's Avatar
I'll try that tomorrow, thanks Billy.
Old Oct 1, 2008 | 09:36 PM
not a problem, make sure you let us know how it goes.
Old Oct 1, 2008 | 10:29 PM
PWevo's Avatar
Any other opinions?
Old Oct 2, 2008 | 05:01 AM
speedypollard's Avatar
clutch is going bad...time for an ACT!
Old Oct 2, 2008 | 03:50 PM
PWevo's Avatar
Tried this today. Rpms did not free rev. The rpms gradually increased as the car picked up speed.
Old Oct 2, 2008 | 08:28 PM
PWevo's Avatar
Any ideas?
Old Oct 3, 2008 | 09:03 AM
Yes, I've seen it a time or 2.....it's an easy check.....
Old Oct 3, 2008 | 06:11 PM
PWevo's Avatar
Thanks, I'll check that out.
D-Man
Mitsubishi TC-SST Discussion
May 26, 2020 12:02 PM
nspyr
26
Jun 20, 2017 02:08 AM
xexitenglishx
Sep 18, 2008 07:17 PM
72Tornado
Jun 22, 2007 11:00 AM
ChodeSlappinFun
Oct 26, 2004 11:07 AM
