Evo 7 driveline shunt
Old Aug 31, 2003 | 08:27 PM
patrickfelstead's Avatar
I'm from Australia, and have imported a new Evo 7 GSR (ACD and AYC etc) from Ralliart New Zealand. I've had the car a few weeks now, and while its a lovely car to drive, but it has this horrible driveline shunt that I'm prepared to do just about anything to get rid of.
Its hard to describe, but basically while driving around town, if I'm driving in 1st or 2nd (sometimes even 3rd) with part throttle and I go over a series of bumps (eg over an intersection), or I back off the throttle too quickly, the car gets into a series of severe forward/backwards oscillations. The problem is compounded by my right foot (accelerator) being affected by the shunt, ie as the car oscillates, it makes my foot unintentionally apply and release throttle, thus setting up another shunt, etc etc.
The only way I can stop is to totally take my foot off the throttle until it goes away. To me it seems to be a combination of extremely sharp throttle response of the car, combined with the very jiggly/twitchy suspension settings.
Is this normal for Evos and I just have to live with it, or is there a problem with my car?
Is it a tuning issue that an aftermarket ECU or piggy back ECU could tune out?
Is it due to the east-west engine orientation, and could an engine damper rod could possibly help?
Could revised bushings or damper settings eliminate the problem?
Thanks
Old Aug 31, 2003 | 08:32 PM
Hungbee112's Avatar
I have that issue with my car too. What I do is upshift to higher gear where i know it gets bumpy. It keeps the throttle response in check. Either that or lay off the throttle like you mentioned.
Old Aug 31, 2003 | 08:33 PM
5StarSuzuki's Avatar
In Timeout
Ha...If this is the same thing as im thinking of... I do it accidently also If your in boost (over 3k) and hit a bump i accidently crack the gas causing a repeat effect... Just put your clutch in...or learn to control your right foot better... I dont do it anymore... But theres a huge *** bump in the road i leave for every day where you have to speed up to get too...then slow down for the bump...then go uphill...At 35mph is feels like your airborn
Old Sep 1, 2003 | 03:18 PM
SILVER SURFER's Avatar
I have also experienced this problem, with my permenantly installed wide band I have been able to see exactly what is happening. Specific combinations of engine load and throttle input, create an overly lean condition causing the engine to hesitate/buck violently.
Aftermarket intakes and DV's seem to increase the likely hood of this event. From what I understand they can make the MAF sensor reading unstable under certain conditions. Adding fuel around these RPM/load points (especially throttle pump correction) should aleviate this intermittent problem.
For me it seems to happen around 3-4K at light/part throttle just as your transitioning from vacum to boost. Adding fuel through a remapped ECU, piggy back, or stand alone ECU, should get rid of this problem.
I believe it is a small hole in the factory fuel/correction maps, ultimately Mitsu should fix it by slightly adjusting the stock maps. It doesn't happen often and I plan to go with an aftermarket fuel control soon anyway so.....
Old Sep 1, 2003 | 08:06 PM
Silver Surfer, thanks a lot, that is very useful. For what its worth, I emailed a company in the UK who do rally preparation on Evo 7's, this is what he thought.
-----Original Message-----
Sent: Monday, 1 September 2003 5:50 PM
To: FELSTEAD, Patrick
Subject: RE: Evo 7 Driveline shunt
It is a feature not a fault, I know exactly what you mean. The cause is that as you have already realised the throttle response is excellent - unlike most average road cars that are a bit "wooly" to the throttle and programmed so deliberatly, there are several reasons for this
  • light throttle return spring
  • light flywheel / clutch
  • engine programming to get throttle response
  • a conflict between the "cush spring" (the clutch centre plate "******" damper arrangement) engine mountings (or engine roll stoppers as I believe you call them down there)
  • the relative lack of freedom of movement in the rear diff and suspension bushings
In summary, its a trade off in return for the "taught" feel in the chassis - which could be removed if an electronic throttle arrangement similar to say BMW utlise was used, which its not primarily for cost and reliability reasons. I can be sure this is the case as when we fit the reinforced clutches and bushings in for Motorsport the problem is amplified making the cars really nasty to drive slowly on road sections.
I can only suggest that you try fitting a heavier return spring on the throttle pedal.
Regards Tim Ashton
GaminKWB
Lancer Engine Management / Tuning Forums
15
Oct 21, 2016 03:48 PM
W0LF
Sep 15, 2016 08:58 PM
l2r99gst
Aug 28, 2011 03:39 AM
topper_bob
Jul 30, 2008 09:47 AM
timzcat
15
Nov 10, 2006 01:58 AM
