MY 2.3L/3076R Build. (56k....haha)
UPDATE:
engine wise;
the car is now running a ported IM and a Mil.Spec 65mm TB, gm 3port and a dual catch can setup. I also ordered the materials to make a maf-less intake for my switch to speed density. I also fabbed up a cam sensor heat shield.
i also put performance friction 2pc rotors and hawk HP+ pads. im also running 15mm spacers in order to increase the front track and a much more more aggressive alignment.
i also got 17X9 5zigen fn01r-c's and some 275/40/17's for my autox setup
yummy
engine wise;
yummy
Very hot and spicy. Good to see you got over the heart-break of me buying those NT03's out from under you. I'm grabbing those same rotors in a day or two. The catch cans look good, did you build them with your new found welding skillz?
Post up a DLL power graph of your current hottness. Or send me a evoscan file of a 3rd gear pull and I'll make one for you.
PS.
You need to find a source of E85 super-fuel. You could get a 55 gallon barrel and just use it as "race-gas" for auto-x.
PS.
PS.
PS.
it still stings a little thinking about the deal you got on the nt03m's.
as for the catch can, the one on the intake side is a weapon-r can that i cut about 3 inches out of in order to make it fit, and the catch on the pcv side i made from scratch.
as for DLL, the program will not work with my copy of vista. I worked with a guy from DLL and we couldnt get it to work no matter what we did. so now ive been trying to write an excel file that will spit out the numbers from my logs. ive got it correct wrt orders of magnitude but its still too high something like 550 whp and 500 wtq. Although that would be nice, i doubt its correct
there is an e85 station about 40 miles from my house, so once some more funds become liquid, im gonna order some 1200's or 1400's and figure out the fuel pump issue. Until then i have this.
unfortunatly torco went out of buisness and i cant get anymore
oh snap is right! i am jealous. I've been watching this build, but the new s200sx makes me even more interested now. can't wait to see results. what manifold are you going to use with it? someone is selling an AFI TS T4 manifold on here for a steal
im going to be running the AFI manifold. i picked a new one off ebay for a good price
Screw you for jumping off the T3 GT3076 train. But, I'm looking forward to seeing how the new twin scroll hottness works out. It should be nasty.
Time to build a new O2 housing and adjust your downpipe, or is the manifold coming with that action.
Ill be building my own O2 and dumps again. It should come out better because my skillz have improved with the TIG
I really wanted to go twin scroll when the RNR crapped out, but I didn't have the time or money. I barely had the cash for the manifold, let alone a new turbo. And at that point i was trying to get it back together for a track day. Only to have my fueling issue make me miss it anyway.
On the tracks up here the 30R is always ready to go out of the corners, it literally makes the car jump like a freaking cheetah when you throttle up leaving the apex. But I could see issues with the on/off digital feel of the powerband on an auto-x course with 1st and 2nd gear stuff.
