4th Gear Problem
Old Oct 12, 2008 | 12:25 AM
Sideck's Avatar
4th Gear Problem
Hi, 2 weeks a go i get a 03 evo... and i have a problem, the 4th gear locked out at 3500-4000 rpms. if i put in 4th gear an floor the gas ´pedal at 3500-4000 the gear locked out!!... i try adjusting the clutch pedal and nothing....still the problem.... this only happen on 4th gear...
when i test the car before buy, this not happen, only grind on 5 gear... i told to the seller the problem, and they remove the tranny and change a bad synchro.... after that the problem come in... do you think is the oil??? im going to change the clutch, but i want to know if can be a synchro, i dont want remove the tranny twice....
Note: i made 2 dig launchs and i get clutch burn olor!!!
thanks...
Old Oct 12, 2008 | 12:33 AM
eponti's Avatar
Is your clutch stock?
Old Oct 12, 2008 | 12:32 PM
Sideck's Avatar
yes, is the stock clutch... (the mechanical tell me that when he removed the tranny), and i think they put sheap oil on the tranny...
Old Oct 12, 2008 | 06:50 PM
Sideck's Avatar
bump!
Old Oct 12, 2008 | 07:00 PM
k2boarder3187's Avatar
sheap oil!!! that sounds baaaaahahadd.
sounds like a clutch problem..
Old Oct 14, 2008 | 12:00 AM
Sideck's Avatar
any one??
Old Oct 14, 2008 | 05:21 AM
El.BlueEvo9's Avatar
Exact thing happens to me but from 1st to 2nd on the high RPM. Most likley the syncros.
Jacks Transmissions
Jacks Transmissions
50
Feb 20, 2016 02:54 PM
taylor
15
Feb 16, 2005 08:10 PM
The Emperor
18
Jul 9, 2004 03:45 PM
JaReDbOy
23
Mar 4, 2004 04:48 AM
