2.3 35r 880cc stock ecu
Old Oct 14, 2008 | 09:18 AM
Evo818's Avatar
i have a 2.3 stroker with a afi 35r turbo kit cosworth 272 cams and 880cc injector's my stock mas-air-flow sensor is about a foot away from turbo and im on stock ecu.... the shop tha built the car said i can only drive my car if i get a stand alone from aem cause i cant tune my car with the stock ecu to drive around and race on
is that true???
i was told by another shop i just need to make a extra bend or stretch out the intake pipe to help out on bogging and jumpin of rpm's and that the tune on here is just wrong thats why the car is not drivable and able to run with out bogging out and dieing at lights....
if im able to still run this set up and stock ecu some have said i can is it true or should i park car and save till i can get a stand alone but if i dont need a stand alone i dont want to get it unless i have to as its the only way....
Old Oct 14, 2008 | 09:21 AM
Dragracer187's Avatar
there are people running 35r on stock ecu, I think Mellon is one of them.
Old Oct 14, 2008 | 09:22 AM
jid2's Avatar
Plenty of people run the stock ECU with your same setup. You just need to find someone to tune it. There are lots of vendors here that do it just search around.
Old Oct 14, 2008 | 09:30 AM
Evo818's Avatar
alright what about the intake with teh mas air flow being so close to turbo or doesn't matter
Old Oct 14, 2008 | 09:34 AM
jid2's Avatar
I'd get the MAF at roughly the same distance from the turbo as it was on the stock setup. That's important.
Old Oct 14, 2008 | 09:39 AM
denolloyd's Avatar
It will be a lot easier for the Stock ECU to idle if the MAF is moved away from the turbo. I had the same issue a few years back. I installed a 35r on my car and it refused to idle. We were baffled for a few days, the finally added an intake with longer bend, and moved the MAF about 8 inches from the original position. After that, it idled just fine.
FYI, I ran a setup similar to yours with the Stock ECU. Good luck!
Old Oct 14, 2008 | 09:42 AM
Evo818's Avatar
thanks the shop was thinking of making it custom and going into the fender where the aps one goes facing the ground like a cold air
Old Oct 14, 2008 | 10:25 AM
denolloyd's Avatar
A cold air solution should work well. My MAF relocation was an interim solution that I never changed. It placed the MAF / Filter towards the upper right side of the Head. Still made good power though.
Im sure these days, tuners should be able to tune with the MAF close to the larger Turbos, but I left mine in the relocated position.
Old Oct 14, 2008 | 10:27 AM
Billy@EnglishRacing's Avatar
you just need a good tuner, i know Johnbradley can tune this sort of setup
Old Oct 14, 2008 | 12:36 PM
Mellon Racing's Avatar
It might just be the tune, can't say that I've tried my stock mas that close before though.
Old Oct 14, 2008 | 12:58 PM
Evo818's Avatar
im in az so im limited to tuners that i trust any more had my share of screw overs from them
Old Oct 14, 2008 | 01:02 PM
yeah and az 91 isn't very knock resistant...you've got a nice setup so it should be pretty efficient and make good power.
Old Oct 14, 2008 | 01:57 PM
denolloyd's Avatar
OP, I dont have any photos of my old setup, but I have a short video. Take a look. You can see how far up I had to place the MAF and Intake in order to get my 35R to Idle (I'm running a 37R in the Vid, but I used the same pipe as with the 35R).
Good Luck...
http://www.youtube.com/watch?v=SwytC0GhqEo
http://www.youtube.com/watch?v=TrDb7PNOUVs
Old Oct 14, 2008 | 02:35 PM
Evo818's Avatar
yea your intake has a bend in it mines just straigh thats probably why and the tune i go into goodspeed tomorrow out here to get a base map put on my fresh motor so well see if that works
Old Oct 14, 2008 | 02:39 PM
precisi0n's Avatar
PM me and I can set you up with someone... I run a 35r with 1000's on stock ecu. I will set you up with my tuner...
ftlvwrx
Jan 24, 2009 07:41 PM
MattyBoyMR
15
Jan 14, 2009 02:27 PM
churchja
Nov 8, 2008 10:38 AM
David Buschur
19
Oct 27, 2005 06:53 AM
