new head gasket :mad:
Old Oct 14, 2008 | 12:36 PM
bevolucion's Avatar
well today I just recieved a new oem evo head gasket I ordered, well this is what I founf freaking gasket is bent apparently on shipping. My ? is can I still use it considering that it will be torque down at 80 ft lbs.
Old Oct 14, 2008 | 12:41 PM
Johnboy1065's Avatar
is it bent so much to where it has a crease in it? If so I definetly wouldnt use it. if it doesnt have a crease then you may be ok.
Old Oct 14, 2008 | 12:42 PM
red evo8's Avatar
+1
Old Oct 14, 2008 | 12:47 PM
bevolucion's Avatar
yeah thanks ,I think this one is going back. I just hate sending things back because some jerk was careless. When I saw the box outside my door the first thing I notice was the bent on the box and I said" f@k, f@k, idiots"
Old Oct 14, 2008 | 12:48 PM
Mulholland0132's Avatar
sucks.
Old Oct 14, 2008 | 01:15 PM
El.BlueEvo9's Avatar
Why didn't you just go to your local Mitsu dealership to get a head gasket?
Old Oct 14, 2008 | 01:17 PM
bevolucion's Avatar
well I bought it as a package deal ,arp head studs, timing belt and the gasket. is cheaper when you get it together.
Old Oct 14, 2008 | 01:22 PM
Ah, O.K.....It's a long shot, but see if the mitsu dealearship can work out something with you. Like I said, it's a long shot, but if it truly is bent up, you might end up with a leak thus having to pull it apart again.........Now, that's just my opinion. But good luck to what your doing
Old Oct 14, 2008 | 01:34 PM
ETS Michael's Avatar
That's a bummer. Usually when we receive a head gasket it's a decent size box, or it's between two really stiff pieces of card board or even wood sometimes. Make sure it doesn't have a crease in it if you plan on using it. More then likely you are better off returning it and hoping the next one comes across perfect.
Good Luck,
Michael
