Stuck manifold bolt
Stuck manifold bolt
Okay so I was changing my exhaust manifold and 02 housing but I ran out of time. (shop was kicking me out haha) I wasn't completely done with the manifold so I had an exhaust leak. I tightened the few bolts that I had on as tight as I could to minimize the leak. But now when I try to fix the leak, I can't get the bolts off that I previously put on so tight. This sounds stupid but its a pain because I can't get the bolts off to fix it
Any ideas to get off stuck bolts?
Try "mouse milk" its and additive that will lubricate the threads for those hard to pull bolts and nuts. Just soke it for 10-15 minutes and you should be able to pull it.
Or if you want just poor a little brake fluid on it and let it soke for the same 10-15 minutes, that will work also.
BUT becareful not to make the brake fluid catch your paint.
Hiboost
Evo X How Tos / Installations
16
Feb 27, 2016 03:33 PM
