Kelford 272 Springs and Retainers
Old Oct 17, 2008 | 03:37 AM
Monkeysphere's Avatar
Just a quick one guys. I have been reading many times that Kelford 272s will require a spring upgrade but i emailed them yesterday and the response was:
"No you do not need to use them. The stock valve spring will be just fine."
Mind you this is on a car that will be keeping the stock rev limit and running no more than 24psi. I have no problem changing them if need be but i wanted to find out for sure if it is actually needed at all because Kelfords official response kind of puzzled me.
Thanks.
EDIT: Sorry guys should have added this to the other thread and now i can't find a delete button.
Old Oct 17, 2008 | 05:12 AM
jezzy101's Avatar
Veteran: Marine Corp
No problems here on the stock springs/retainers, although I wouldn't take it past 7900 rpm's.
Old Oct 17, 2008 | 06:33 AM
Evolessfornow's Avatar
$250-400 is cheap insurance to protect the engine.
Old Oct 17, 2008 | 06:55 AM
Kracka's Avatar
The stock springs/retainers are fine with Kelford 272's as long as you stay at stock rev-limit.
Old Oct 20, 2008 | 10:46 AM
booster9's Avatar
+1
im rocking kelfords with stock springs. and i havnt had any problems yet.. the kelfords are not much bigger than the HKS 272s with a max of 10.8 lift where the kelfords are 11. i just keep a close eye on my rev limit, and try to not hit it.. definatly keep the rev limit at 7.5k!!
the cams are AWESOME! btw
Evoguy!123
Mar 24, 2017 10:50 AM
99evoVI
Feb 1, 2016 04:53 AM
740 Turbo Brick
Nov 8, 2015 12:24 PM
sovietEVO
For Sale - Part Outs
Jun 25, 2014 04:02 PM
Mauricio Evo IV
Nov 17, 2011 09:18 AM
