buschur small battery
Old Oct 18, 2008 | 12:16 AM
Dragking2189's Avatar
hi guys i bought a buschur small batery kit 6 month ago i always had problems with the battery , it will loose at Its charge if the car was parked at home for 3 days without use ... it's been a full week i dont drive the car and i notice that the battery ended messing up any one know where can i buy just the small battery thanks????
Old Oct 18, 2008 | 12:18 AM
bluebanana23's Avatar
or relocat a full size battery to the trunk
Old Oct 18, 2008 | 08:25 AM
VRSF Tiago's Avatar
You're gonna have the same issue with any small battery.
If you've had it for less than a year I'd go through the manufacturer to get a replacement under warranty (call buschur and they'll tell you who to call).
I'd recommend you either install a battery kill switch or relocate the battery to the trunk
Old Oct 18, 2008 | 08:28 AM
jid2's Avatar
It's an Odyssey PC 680
Old Oct 22, 2008 | 05:09 PM
Dj M@nny's Avatar
Im about to need to get a small battery kit soon cause of the uicp. Ive read in some post that many of these batteries die soon. I will like to know whick of these small batteries is the best of them all?
Old Oct 22, 2008 | 07:44 PM
David Buschur's Avatar
If the battery is draining in 3 days it is probably not the battery's fault. The batteries have proven to be excellent but they only have so much capacity. All new cars have things that drain the battery down. My guess is you have an excessive drain coming from something.
To give you an idea about how much drain new cars have, new VW's come with a solar powered battery charger when they are shipped here. They are stuck to the windshield with suction cups and plugged into the OBD2 port. When the cars are put on the lot and sold they are taken out. I know this because I have a good friend that works for VW and he gives me all these panels that get thrown out. I am almost to the point I can power a small town
Anway, check for some excessive drain from something, the battery should not lose a charge in 3 days. If you park it at your house for 3+ days I'd recommend getting a $25 battery tender from Walmart and putting it on the car. The work kick ***.
Old Oct 22, 2008 | 07:59 PM
StreetThisEvo's Avatar
I've had my BR battery kit for a year and a half and have never had an issue.
Old Oct 22, 2008 | 08:09 PM
whitey4d's Avatar
Mines from June of 2006. I only drive my car once a week at that and it always cranks fine. Except after it sits for 4 months in a pole barn all winter.
If you want to check to a parasitic draw unhook the neg terminal and connect an amp meter the cable and the post. Any think over a couple of amps is excessive.
Old Oct 23, 2008 | 06:18 AM
El.BlueEvo9's Avatar
What's the price on those things?
Old Oct 23, 2008 | 08:08 AM
andrewzaragoza's Avatar
they usually go around this price. http://store.summitracing.com/partde...part=ody-pc680
Old Oct 23, 2008 | 10:13 AM
Gusl's Avatar
I have the Buschur battery kit on my car for a good 2 years now. yes, if it sits for more than 4 days its really hard to start. I did what dave suggested, i went to discount auto oparts & bought the Schumacher 1.5 battery tender. Its $25 & it works great. No issues anymore. It actually extends the life of the battery.
Old Oct 23, 2008 | 10:22 AM
SlowScooby's Avatar
If you don't want to mess with the battery tender just undo one of the terminals on the battery if you know it will sit for a few days to prevent it from draining.
sterlinge
10
May 1, 2017 05:43 PM
17579EVO9MR
Mar 13, 2017 06:31 PM
17579EVO9MR
May 27, 2011 07:46 PM
evane
Nov 14, 2008 08:58 AM
ggevoIX
Oct 27, 2008 07:54 AM
