Weird shifting problem
Old Oct 19, 2008 | 04:50 PM
Skylineracer's Avatar
From: Clifton New Jersey Lived: Daytona Beach, Florida Lived: Port Orange, Florida
Sometimes when i shift from 1st or 3rd it feels like i am snatching it out of the current gear. I have made sure that i have the clutch in all the way and sometimes it still happens. I think i might need to adjust the clutch pedal but i am not sure. Its still on the stock clutch.
Old Oct 19, 2008 | 04:52 PM
Clutchdc5's Avatar
that happened to be back then, where it just POPS out with me slowly bringing out, i always thought my shift forks were gone
Old Oct 20, 2008 | 12:08 AM
anyone else?
Old Oct 20, 2008 | 12:11 AM
importjake00's Avatar
Mine only like that when im lazy and dont push the clutch all the way in.
Old Oct 20, 2008 | 12:27 AM
porsherules911's Avatar
well stop being lazy u bum
Old Oct 20, 2008 | 12:34 AM
Duh Panda's Avatar
try adjusting it... should fix the issue...
if not then well... new clutch possibly?
how many miles?
Old Oct 20, 2008 | 09:47 AM
16,7xx- 1 launch
grabs fine only gripe is the vibration noise i get sometimes from the TOB but thats been there since day one. this crap with the shifting is recent
Old Oct 20, 2008 | 05:21 PM
Jay644's Avatar
Mine pops out of first sometimes also. I adjusted the clutch almost all the way to fix another problem (gears locking out at high speed) but I still have the 1st gear pop out from time to time. I think I'm gonna do the TRE 6speed rebuild.
Old Oct 20, 2008 | 05:34 PM
huevosrancheros's Avatar
either try putting in some fresh tranny fluid or adjust your clutch pedal.
If none of those work check the shift linkage and give it a good visual inspection.
Old Oct 20, 2008 | 05:38 PM
i did the fluid over the summer, adj. the pedal is on my to do list for 2morrow but i am not sure as to how to adj. it (should i go in or out), and what should i look for when checking the linkage?
Old Oct 20, 2008 | 05:43 PM
You want to adjust the rod clock wise. Evomoto.com has a great article on it. Look for the article under the tech section.
As far as the linkage, check to see if its moving smoothly and most importantly is the shift linkage binding??? The cables are located under and behind the battery. Once you get that battery out of there, it would be a good time to upgrade the shifter bushings.
Old Oct 20, 2008 | 05:44 PM
BocaShula's Avatar
Mine does the same thing...
Old Oct 20, 2008 | 05:52 PM
PWevo's Avatar
Mine does that every now and then, but my clutch is slipping though.
Old Oct 20, 2008 | 07:00 PM
i will try to adj. it 2morrow and will report back
