My AMS 2.0L build
Old Oct 20, 2008 | 06:45 PM
althemean's Avatar
My AMS 2.0L build
It has been a long time coming. For those who remember (which I doubt is anyone) I blew my motor in April of 2006. The number 4 piston popped and the detonation blew a rocker arm off the exhaust valve in the head.
After 2.5 years (almost 1 year per liter hmm...) I finally got the cash to purchase the shortblock. My orginal intentions were to rebuild the engine myself. Well, a back injury later (not related to the evo) a child being born, and working two full-time jobs the project fell by the wayside. I had pulled the engine out in June 2006 and there it sat. I slowly collected parts. But due to the lack of time I wanted the car to be sent to Chicago so AMS could do the build. Oddly enough having a non-running car minus the engine costs more to transport than a running vehicle. I kept trying to reach that magic number of 7k to have the car rebuilt. That never happened. I kept coming close but life (wife) always sucked my wallet dry.
To conclude my little anecdote, the AMS 2.0L shortblock arrived this morning. I hung it on the engine stand and I am beginning to transfer parts over.
So far I have:
JUN 264 cams
Cusco twin disk clutch
ARP head studs
New oil pump/water pump
AMS 2.0L shortblock
stock headgasket (new)
Rebuilt Cosworth CNC head (from AMS)
There is probably more but I cant remeber it all.
Here are some pics
Attached Thumbnails My AMS 2.0L build-evo-eng-rbld-028.jpg   My AMS 2.0L build-evo-eng-rbld-029.jpg   My AMS 2.0L build-evo-eng-rbld-030.jpg   My AMS 2.0L build-evo-eng-rbld-032.jpg   My AMS 2.0L build-evo-eng-rbld-034.jpg
Old Oct 20, 2008 | 06:50 PM
Sharkbite2000's Avatar
Long build , GL
Old Oct 20, 2008 | 06:51 PM
MR Turco's Avatar
Good luck, sounds like it has been quite a journey.
Old Oct 20, 2008 | 06:59 PM
1d10t's Avatar
your patience will pay off. Congrats dude
Old Oct 20, 2008 | 07:03 PM
Ivan@AMS's Avatar
Good luck with the build. If you have any questions or need advice, feel free to PM me.
Old Oct 20, 2008 | 07:40 PM
althemean's Avatar
I am hoping that the hard part is over. I cleared all my major obstacles. The only one remaining is the tune.
I also now have a full set of spares. BR spec JE pistons, Carillo rods and the engine core itself. I am thinking of keeping the core to build the original motor to have an extra one lying around.
Shelf full of labled parts
Old block ready for disassembly
Crank ready to come out
Crank removed
Attached Thumbnails My AMS 2.0L build-evo-eng-rbld-037.jpg   My AMS 2.0L build-evo-eng-rbld-049.jpg   My AMS 2.0L build-evo-eng-rbld-054.jpg   My AMS 2.0L build-evo-eng-rbld-058.jpg   My AMS 2.0L build-evo-eng-rbld-059.jpg
Old Oct 21, 2008 | 11:13 AM
althemean's Avatar
I removed the oil pan last night. The thing was full of metal shavings. Thats interesting because I thought When I drained the oil I didnt notice and metal in it. I suppose it came from the piston when it broke apart.
I dunked it in a solvent tank this morning and cleaned all the old seal off. I need to remove the oil filter housing and do the same.
I will post pics when I get it home.
Stock pistons
Stock oil pump and balance shaft
Stock block completely torn down
Attached Thumbnails My AMS 2.0L build-evo-eng-rbld-060.jpg   My AMS 2.0L build-evo-eng-rbld-061.jpg   My AMS 2.0L build-evo-eng-rbld-062.jpg
Old Oct 21, 2008 | 06:20 PM
Ivan@AMS's Avatar
Please change your oil cooler out prior to installing your new motor. Any shavings in the oil cooler will make their way out eventually and will contaminate your new bearings. No matter how much you try to clean the cooler, you will never get everything out.
We have an upgraded one that comes with new lines and such. It is cheaper than the factory oil cooler. Details can be found in our online store.
Old Oct 21, 2008 | 06:28 PM
mk4thewin's Avatar
What turbo are you planing on running with that?
Old Oct 21, 2008 | 06:34 PM
althemean's Avatar
I also want to thank AMS for their support.
Darius and Scott you both have been a big help.
Thanks a ton for getting me that Cossie head. It will put my mind at ease.
Pics to come as soon as I can upload them.
I disassembled the old motor this morning. The only thing left in it is the oil squirters. Apparently the metal in the oil pan was all piston. The bearings are slightly scored from it but the crank journals are clean. None of the bearings were spun.
The balance shaft surprised me. I never realized how much it actually weighs. Same for the oil pump. I wasnt expecting it to be designed like that. I guess it comes from working on older cars where the pump was an external housing. I have never rebuilt a mitsu eng before.
Old Oct 21, 2008 | 06:37 PM
althemean's Avatar
So far it will be the stocker. I am blowing my wad on the longblock. I will probably end up with the FP green or maybe the new CBRD when others have started using it and real results show up.
Other parts I have:
Fidanza gears
720cc inj
AEM EMS
JIC DP and Exh
Cat delete
Coated O2 mani and Exh Mani (not ported)
APS BOV
Walbro 255
Old Oct 21, 2008 | 06:41 PM
althemean's Avatar
You guys tryin to make my OCD act up? I am gonna need some ambien to sleep now dammit.
Thanks for the heads up. I forgot about that one.
Old Oct 21, 2008 | 06:45 PM
h22gordo's Avatar
Very nice! And you had the block o-ringed.......she should be a screamer.
This is the same route I will be going.
Old Oct 21, 2008 | 06:53 PM
AudiA4_20T's Avatar
I love personal DIY projects
Old Oct 22, 2008 | 11:17 AM
althemean's Avatar
more pics added, more to come
