Car cuts out with Test Pipe installed
Old Oct 20, 2008 | 07:48 PM
killme4food's Avatar
OK, here we go.. B4 i installed the testpipe i had the cat. Boost was set to 22psi. had no problems at all.. no knock or anything in 4th gear... Now when I installed my Testpipe i went for a drive.. around 4500-5000 the car just cuts out and then goes right back to what it was doing.. Boost dies all the way down, Then shoots back up.. Not sure if its fuel cut or something else. When the car "cuts out" i get a count of 7 knock... I turned the boost down to 21 and it still did it. but only got 4 knock. It wasnt doing this with the cat installed.. What could be the problem??
Mods are in sig
Old Oct 20, 2008 | 07:50 PM
EVO8emUp's Avatar
Sounds like fuel cut.
broddey's Avatar
Its called boost cut. The newfound lack of backpressure is causing your turbo to spool a lot faster, initiating the boost cut.
Retune and research.
Old Oct 20, 2008 | 07:52 PM
doesnt the cobb take care of that.. i have the stage 2 which is for no cats
Old Oct 20, 2008 | 09:36 PM
loCo eVo VIII's Avatar
shouldve bought a white evo mike lol
Old Oct 20, 2008 | 09:42 PM
EvokidIX's Avatar
Are you using the Prosport gauge to monitor your boost? if so, most of their boost gauges are off by like 3 or 4 psi
Old Oct 20, 2008 | 09:45 PM
StealthaPsYcHo's Avatar
Old Oct 20, 2008 | 09:49 PM
no i got a different gauge now.. autometer.. my prosport was broken
Old Oct 20, 2008 | 09:56 PM
Jay644's Avatar
Which prosport boost gauge were you using? The mechanincal, or electric?
Old Oct 20, 2008 | 10:05 PM
mechanical.. it worked for almost a year.. then crapped out.. was only hitting 15lbs.
Old Oct 20, 2008 | 10:07 PM
Evo8luva's Avatar
first, prosport is junk...
second, assuming your running the cobb stage 2 map... that map is to be used with the stock BCS. Boost cut on that map is somewhere around 23-24psi, and it only has to be there for 1000ms for it to cut out. Also cobbs off the shelf maps (stage1 and stage2) are for a STOCK car or ONLY a turboback. the intake will throw the tune off, especially a high flowing intake like buschurs.
turn the boost down a little more, that will probably clean up the knock for now, get tuned, and enjoy!
Old Oct 20, 2008 | 10:19 PM
ive turned it down 1lb so far.. so 21lbs.. and i do get less knock.. but that "boost cut" or w/e it is is still there.. im guna turn it down another lb and see if it goes away.. seems like it only happens in 4th gear.. oh and its Starting to get Really cold at night by me.. maybe that has something to do with boost too?
Boostd4
142
Jul 20, 2013 04:41 PM
mac214
Mar 18, 2009 02:33 PM
BenJ
Oct 30, 2007 11:50 PM
Thegame
10
Jul 25, 2007 12:01 PM
sgplancer
11
Aug 26, 2004 06:00 AM
