EVO topend = gh3y??
Old Sep 3, 2003 | 09:07 AM
caymandiver75's Avatar
Originally posted by 93civEJ1
how much is one of the works reflash? and do you send in your ECU and they flash it or do they send a whole new one? I really cant be without my car as it is my daily driver and only mean to and fro.
WORKS ecu flash is 450.00. From the results I have seen it is a good bang for the buck.
Old Sep 3, 2003 | 09:08 AM
93civEJ1's Avatar
any noticibly different gains?
Old Sep 3, 2003 | 09:31 AM
Jonasan50's Avatar
yeah obviously I need something....just dont know what yet...may a DP or something?? the car just feels like it falls on its face in any gear after 5,000rpm.
Lean that ***** out and that fall will disappear!! It's so rich in the higher rpm's that it feels that way...
Old Sep 3, 2003 | 09:36 AM
Yeah there is a notciable difference. Usually if you gain more than 5hp you can usually tell by the butt dyno, but we are talking almost a 30hp linear gain above 4000 rpm.
Old Sep 3, 2003 | 09:47 AM
slt's Avatar
slt
Im still missing where that extra 30 hp is evidenced by your dyno graph
Old Sep 3, 2003 | 10:02 AM
Jonasan50's Avatar
Get an exhaust and that 30hp appears all over the place...
Old Sep 3, 2003 | 10:04 AM
instigator's Avatar
It is a very messy graph. The GREEN is the stock numbers. The red and blue are both modded reflashed.
Old Sep 3, 2003 | 10:21 AM
slt's Avatar
slt
Ahhh, makes sense now. I was ignoring the green line.
Old Sep 3, 2003 | 10:36 AM
bigd's Avatar
Get an XEDE with the Plug and Play cable. Then you can plug in a plain stock SubZero map for now and when you mod, you can tune for it yourself or get a map that suits your mods.
Reflash = Black box, you can't see the tuning, you can't modify it yourself and you may ending up sending it back again or paying again if you modify.
XEDE = create/download a file with MAF, Timing and boost maps and burn it.
Stock Evo with XEDE pulls all the way to redline.
http://www.vishnutuning.com/xede_evo.htm
Old Sep 3, 2003 | 10:39 AM
93civEJ1's Avatar
yeah....i think i will start with the basic "unoticable by mitsu" mods... ie...DP, etc.
Old Sep 3, 2003 | 05:43 PM
Mach V Dan's Avatar
Um, what he said...
Our results:
The biggest gain by FAR was from leaning out the mixture above 5000 rpm.
--Dan
Mach V
MachEVO.com
Old Sep 3, 2003 | 06:13 PM
EVO_RPM's Avatar
Nice numbers. That is what i'm probably going to do
Old Sep 3, 2003 | 06:15 PM
93civEJ1's Avatar
how would I do that??? like an SAFC or something??
Old Sep 3, 2003 | 08:52 PM
mrdecibel's Avatar
Yes the SAFC will do the job. So will the HKS AFR, XEDE, Reflash, standalone etc. By far the best bang for the buck is the SAFC or the AFR. Easy way to gain 30WHP and when you decide to upgrade, the parts can be sold easier than lets say a "Reflash" or anything custom tailored to the EVO. I just recently insalled the SAFC2 and it is a whole new car after 5K
Old Sep 3, 2003 | 09:10 PM
AWDEVO8's Avatar
ok, your problem has nothing to do with some "flash" thing, the stock evo's ecu makes the A/F ratio extremely rich in high rpm's. It does this to keep you from blowing up the motor! If you want to make more power in high rpm's, get an AFC. Then you can decide how lean to make it. you will gain a lot of hp in the high rpm range... one thing though, dont blow it up!
