EVO topend = gh3y??
Originally posted by AWDEVO8
ok, your problem has nothing to do with some "flash" thing, the stock evo's ecu makes the A/F ratio extremely rich in high rpm's. It does this to keep you from blowing up the motor! If you want to make more power in high rpm's, get an AFC. Then you can decide how lean to make it. you will gain a lot of hp in the high rpm range... one thing though, dont blow it up!
I would say that a "flash" is the easy thing to do although it is more expensive. If you know what you are doing, go with the AFC. it is easier and you can adjust it based on weather. I think a wideband and an AFC are the best way to go.
Maybe you're experiencing this problem?
https://www.evolutionm.net/forums/sh...threadid=34867
Originally posted by RENN-ART
get a boost controller, an a/f controller, hks 272 cams, and a turboback exhaust..
say bu-bye to the srt-4!
Re: EVO topend = gh3y??
Originally posted by 93civEJ1
Does everyone elses evo feel like it sucks after 4500 or rpms topend? I am coming from an SRT-4 and the EVOs topend feels like crap...am I the only one that feels this way? everything else is
may be that i am used to the torque distributed through 2 wheels instead of 4??
Good luck. BTW, Where you at in TN? I am in West KY right now and I will be in Nashville next weekend.
Josh
Re: Re: EVO topend = gh3y??
Originally posted by 90GSX-03EVO
After 4500 rpm and it feels like power falls off.....hmm......maybe because the stock boost solenoid pulls the boost from 18 psi to about 16 psi in the evo over 5000 rpm. That would sure do it right there.
--Dan
Mach V
Re: Re: Re: EVO topend = gh3y??
Originally posted by Mach V Dan
I experimented with the boost a bit at the dyno, and didn't see NEARLY the power gain from a pound or two of extra boost, compared to what I got by increasing the air/fuel ratio. My car has 50 more horsepower (at the wheels) than it did when I got it. You won't get that from boost alone. (Not even from full exhaust and intake and boost.)
--Dan
Mach V
--Dan
Mach V
The power droping off at the higher RPM >5k seems to be a combination of factors:
1. Tha A/F ratio is horribly rich above 5K under boost.
2. If you use poor quality fuel/91 oct the ECU starts pulling timming, if you run a good 93oct the power drop off is not as bad. Just compare dyno graphs from places like CA to most every where else, knock retard is very obvious.
3. The boost tappers down rather fast above 5K.
Fixing any one of these three things will give you more top end power, some work better than others. Based on all of the info and testing so far, you can run much leaner than stock with a very good safety margin. You need to know what ratios to use based on the quality of fuel available to you. From the current data mid/low 11's with 93OCT and mid/low 10's on 91OCT. This is just from my observations, obviously there are other considerations when tunning. For example if your significantly increasing air flow (higher boost, big turbo, cams, etc) or advancing the timing you probably want to add more fuel.
Just summing up what's already been said here and throwing in my 2 cents.
vigilante
17
Nov 15, 2006 03:38 AM
evolvedmb
45
Jun 19, 2005 07:27 PM
nrcooled
12
Mar 29, 2005 12:42 PM
