Does this look like every other hotside? porting pic inside.
Old Nov 3, 2008 | 07:34 AM
ultimatesteve's Avatar
Heres a pic of a very small portion of a ported hotside.
Old Nov 3, 2008 | 11:07 AM
No one has anything to say about my work? Come on now. It wouldn't be evom without some wise guy know it all comments.
Old Nov 3, 2008 | 11:09 AM
scorke's Avatar
Good job grinding metal on top of a VP can with two high temp electrical devices on top?
Scorke
Old Nov 3, 2008 | 11:10 AM
reef_420's Avatar
Did you port the whole thing level? When I got mine back from ppi there was a little lip where the exhaust fins go into it. Just wanted to throw something out there. The polishing looks A++
Old Nov 3, 2008 | 11:12 AM
EmeryatSTM's Avatar
^ Lmfao
Wicked E's Avatar
The CDFireman would be proud of you...
-E
Old Nov 3, 2008 | 11:13 AM
scorke's Avatar
Originally Posted by EmeryatSTM
^ Lmfao
I try Emery
Scorke
Old Nov 3, 2008 | 11:30 AM
badhabit90's Avatar
not bad porting. have you also ported the wastegate area?? i did mine and no more boost creeping...this is just after silica blasting it prepping it for thermal coating...
Old Nov 3, 2008 | 11:48 AM
I do a lot of work for people in the norcal area and although I don't port the WG opening I have never got boost creep. This is a red so initially there isn't the lip there like a stocker or green, it's actually slightly in reverse order as I had to remove material outside of where the turbine sits in order to smooth out the transition. Even on a stocker my porting is substancially different then ttp as I have reported their stuff with gains. I believe those gains are maid almost entirely from inside the collector area though since they don't do much past gasket matching it. For a company that offers porting to the public for a set price, they do do a pretty decent job.
As for the can, it's empty and has been for some time and I don't do my porting on it, just put it there for a pic cause it looks better then a bench.
Old Nov 3, 2008 | 01:59 PM
denver's Avatar
I ported my red the same way, but I didnt do all the polishing..... I couldnt let myself put it together knowing that lip was there!
Old Nov 3, 2008 | 02:35 PM
SpoolnupTuning's Avatar
need a better pic or closer! I hope this is for a red!!
Old Nov 3, 2008 | 03:06 PM
yeah it's a red. Don't worry, I wouldn't open the area around the turbine like that. I'll post another pic up when I get home from work.
Old Nov 3, 2008 | 03:55 PM
RevMoto's Avatar
Yea definitely need a closer pic.
Old Nov 3, 2008 | 05:55 PM
Old Nov 3, 2008 | 05:57 PM
Heres a boost plot from a VIII turbo with a 10.5 hotside I ported.. Held boost great with no taper at all to redline.
