Plastic 8DV to Metal 9DV problems.
Old Nov 5, 2008 | 05:11 AM
dpacific's Avatar
I swapped the plastic blow off valve for the Metal 9 one yesterday, now i get a really bad flutter when the air is discharging ? The plastic one ran fine - i checked all my clamps, everything is tight - and the car idols fine so the vacuum tube is fine. Is it just a faulty bov?
Old Nov 5, 2008 | 05:14 AM
gsrboi80's Avatar
Did you put it on backwards? Lower port goes to the UICP side port to the Intake
You will get a bit more part throttle flutter with the metal IX valve though
Old Nov 5, 2008 | 05:21 AM
Jim in Tucson's Avatar
Nope. That's normal. You need an APS BOV/DV. Expensive, but worth it.
Old Nov 5, 2008 | 05:37 AM
dpacific's Avatar
Maybe I put it on the same way the plastic 8 one came off. bottom to the intake and side to the UICP, why would it be switched? the internals f the bov match up the same? At full boost it discharges very fluttery
Old Nov 5, 2008 | 05:48 AM
gsrboi80's Avatar
Its backwards then. The bottom port needs to go to the UICP and the side to the Intake. Someone obviously had the black plastic DV off before be it the dealer, shop, or the past owner and didn't install it correctly.
Flip it around and you'll be straight. You'll likely notice that when its surging the car wants to buck a little
Old Nov 5, 2008 | 06:11 AM
dpacific's Avatar
I feel retarded, Never owned a turbocharged car before. So some of the stuff is new to me. ha thanks
Old Nov 5, 2008 | 06:24 AM
gsrboi80's Avatar
No biggie thats what automotive forums are here for. Glad to help did it fix it ?
Old Nov 5, 2008 | 06:25 AM
Skylineracer's Avatar
From: Clifton New Jersey Lived: Daytona Beach, Florida Lived: Port Orange, Florida
????? i get no fluter with my stock ix bov
Old Nov 5, 2008 | 06:40 AM
dpacific's Avatar
I'm at work, but on my lunch break i'm going to go out and rotate it.
Old Nov 5, 2008 | 06:56 AM
gsrboi80's Avatar
Sweet. I always tinker with stuff on lunch too
Old Nov 5, 2008 | 09:16 AM
BBS's Avatar
BBS
Don't listen to him. Its on backwards easy fix.
Lytec
21
Aug 1, 2019 02:03 PM
taylorgang
May 21, 2011 09:34 PM
rartist
13
Apr 12, 2008 08:48 PM
rartist
Apr 11, 2008 06:55 PM
AhmadHasib
Aug 30, 2006 08:16 PM
