Oil cooler delete
Old Nov 7, 2008 | 06:47 PM
Ted B's Avatar
Well there you go, I wasn't even aware of it.
Old Nov 7, 2008 | 07:02 PM
nothere's Avatar
Originally Posted by SloRice
It's you're own fault you live in the desert.
I could care less about running my car with or without an oil cooler in NV because I don't live there.
Also...I have some interesting test data of oil temps with and without the cooler. You'd be surprised.
surprise us.
Old Nov 9, 2008 | 10:13 AM
LoKiEvo's Avatar
So what are people using to plug up the hole for the oil cooler lines... im looking to get rid of mine too What size bolts and how long are they? Any help?
Old Nov 9, 2008 | 10:47 AM
StreetThisEvo's Avatar
I agree someone needs to post pics or part numbers for what is needed to delete the cooler. I will be removing mine this winter to clean up the engine bay and get rid of a pound or two.
Old Nov 9, 2008 | 10:52 AM
psphinx81's Avatar
agreed, i would like to get rid of mine as well.
Old Nov 9, 2008 | 12:47 PM
1badgsex's Avatar
i spun my balance shaft bearing couple of months ago and just got back my motor from buschur (stage 3) and iam getting rid of the oil cooler when i finish the build, mainly because there is metal shavings in it and takes up room and weight.
Old Nov 9, 2008 | 12:54 PM
Billy@EnglishRacing's Avatar
this idea would scare me
Old Nov 9, 2008 | 01:06 PM
fugiwara's Avatar
Turbo car produce lots more heat especially 4g63 is known for it's heat problem, by having the oil cooler there, it'll maintain proper operating temperature, extend the life of motor.
Even for normal daily driving, you still will have fun with your car, doing WOT etc. under those condition the oil temp rise fast, if you don't have oil cooler the temp is going to rise even faster.
Old Nov 12, 2008 | 01:47 PM
evremonde's Avatar
I'd imagine an hour at faster highway speeds (>70 mph) could heat up the oil enough to need the cooler.
Wont the turbo always be spooling a bit at those speeds?
Seems like youll make your car more impractical then it needs to be, in order to save maybe 5 lbs and few dollars on each oil change?
I'd want to test it thoroughly and would be ready to put the cooler back the first time temps got to high.
Old Nov 12, 2008 | 01:56 PM
scorke's Avatar
Would you donate your blood if you couldnt make more>
Scorke
gudmundur
AEM EMS
Jan 16, 2009 04:15 AM
gudmundur
Dec 13, 2008 07:04 PM
gudmundur
May 18, 2008 06:26 AM
gudmundur
Feb 11, 2008 10:19 AM
gudmundur
Mar 12, 2007 09:37 AM
