Pt 6262 63a/r or 82a/r?
Old Feb 13, 2010 | 12:11 PM
  #31
norcalSRTrida's Avatar
i have the 6262/.63
ultimately, i think it all comes down to:
a) how much of this is a DD?
b) where do you rev?
c) how high will you boost?
if you are mainly DD w/ a lil fun, go .63
if you are 2.3 and want a fun powerband... go .63.. otherwise id take the opportunity to go .82 rev out longer, and make more power doing so on a 2.0 or 2.2LR
if you are going to be seeing 30+ often, go .82
i dont know the gains of switching from the .63 to a .82, but GENERAL consensus for any turbo is, you lose about 300rpm spool...but if i had to guess, your power is going to increase anywhere from 20-40hp in the upper rpm range and continue to increase the more you raise the boost..
find your needs, and fit the turbo/turbinehousing to that app...my 2c
Old Feb 13, 2010 | 12:25 PM
  #32
Colt4g63's Avatar
Im running a .63 ATM and see 38psi by 5150-5200RPM in a 3rd gear pull on E85. Im thinking of stepping up to the .82 so i can run some more boost and free up some back pressure at these high boost levels.
Old Feb 13, 2010 | 12:48 PM
  #33
jesus. at 38psi, im sure you're hindering power a TON w/ the .63!
Old Feb 14, 2010 | 06:32 AM
  #34
ranz's Avatar
at that level of boost, for sure you're loosing power at high end.
Old Feb 14, 2010 | 06:47 AM
  #35
ranz's Avatar
Originally Posted by EVO(boss)
i'm running 2.3 HKS stroker on my car and i'm ordering a 6262 /82 A.R so what rpm would I spool at ? how much whp can i get on pump gas 91 ? also if i put some meth with 91
it depends on your tune. but i think you should see full boost with .82 between 4800-5000 rpm. i dont know how much whp you will see on 91oct but on 93oct 24-25 psi boost you will be around 450whp(on dll).
Old Feb 14, 2010 | 08:31 AM
  #36
EVO(boss)'s Avatar
OHH 4800-5000 rpm really that is lagyyyyyy...
Old Feb 16, 2010 | 01:10 AM
  #37
ranz's Avatar
getting 30psi at 4800 rpm on pt6262/.82 is not that lagy.
Old Feb 16, 2010 | 05:26 AM
  #38
R/TErnie's Avatar
wait til you ride in it... lag won't be the first word that comes to mind!
I got the .82
I plan to do a back to back with the journal vs. ceramic BB... and a back to back on the turbine housings (.63 to .82) at several boost levels.
Old Aug 26, 2010 | 04:08 AM
  #39
EVO(boss)'s Avatar
but i think .63 is better for 2.3L coz you can't rev up to high rpm like 2.0L ..
for 600whp on 2.3 i think .63 is the best one
Old Aug 26, 2010 | 08:49 AM
  #40
Broham's Avatar
is the dbb worth the extra money over the journal? isn't the stock evo 9 turbo journal bearing? it lasts a long time. i assumed you can rebuild the journal bearing as opposed to the dbb which needs a cartrdige. is the dbb needed if you'r ejust going to dd and have some pulls every now and then? chime in anybody
Old Aug 26, 2010 | 09:21 AM
  #41
tunechi's Avatar
I say .82 for more poweer what's a few hundred lag for more power
Old Aug 26, 2010 | 10:16 AM
  #42
VRSF Tiago's Avatar
More power assuming you can rev it out...
Old Aug 26, 2010 | 01:52 PM
  #43
4doorstreetbike's Avatar
63 ar ..I get full spool of 31 psi at 5,200 with s2 cams 2.0 liter, also the 63 housing is good till 700 whp.
Old Aug 26, 2010 | 01:58 PM
  #44
Gary@MellonRacing's Avatar
.82 for some top end power
Old Aug 26, 2010 | 02:23 PM
  #45
True but at that point i'm gone..
