Interested in 2.1 destroked from Slowboy
Old Nov 7, 2008 | 04:52 PM
1320awd's Avatar
Just needing peoples opinions on this swap it will be used with a Mivec head. I just want to see how reliable this setup is and any negatives I could be facing. I have searched but didnt find too much info with the Mivec head
Old Nov 7, 2008 | 06:36 PM
steelcityevo8's Avatar
You just suffered a failure correct??
Please dont set yourself up for another!!!!
The only 2.1 in the land worth running is built by AMS for a very steep pricetag. But if you got the grip do it.
If not just consider going 2.0 or 2.3 , And only 2 in the land worh having doing the build . Buschur Racing or AMS
I know why you are looking into the 2.1 cause the 4G64 blocks are cheap and you can use your crank for the destroke. Look around for usable blocks there out there.Trust me I suffered a failure as well that required a good used block. but I found it for a good price.
And it was game on with Buschur Racing .
Maybe send Mike @ AWD motorsports a pm , I remember him saying he always has alot of blocks / heads etc.
Old Nov 7, 2008 | 06:49 PM
sparky's Avatar
I am curious about this 2.1 configuration. So, it is the 4G64 block with a 4G63 crank? What is the bore and stroke? What about rod length and pistons? Is this a quick revving setup?
Old Nov 7, 2008 | 09:13 PM
Evo8luva's Avatar
https://www.evolutionm.net/forums/sh...ht=end+stroker
read that.
i wouldnt waste the time with a 2.1 de-stroker unless it was a 42r car that i wanted to attempt to rev beyond 10000rpm all the time
2.0 is where its at!
Old Nov 8, 2008 | 03:23 PM
CO_VR4's Avatar
Slowboy has had a series of well publicized failures with their 2.1 engines in the past. I can't speak for what they produce now.
There are a number of shops that build quality shortblocks, including 2.1L motors.
Magnus has been building a variety of high end strokers for years. RRE builds good motors in SoCal. Buschur and AMS are well known and build good motors, but they are certainly not the "only 2 in the land worth doing the build".
Old Nov 10, 2008 | 08:54 AM
SBR INC's Avatar
None of the shops you mention do ALL of their machine work in house as we do... we have more quality control built in here than 99% of the shops in the US, especially when it comes to motors - this is the main reason we build so many - !!
The last 2.1l we used ourselves in competition was 07 Rally America at 100 ACRE WOOD Rally - we finished on the podium with a 2.1l built here in our EVO IX. If our 2.1l can work under these conditions - it can work in your street car.
The only known failure on EVO M with a 2.1l was an overzealous customer who liked to use to much grey RTV... however it was easier to blame us. Who would want to admit they put enough RTV on an oil galley block off plug to block oil from getting where it needed to go... ??? No one would - so blame us for the rod bearing failure that had no oil getting to it.
I also used a 2.1l in most of my own DSM's - and even bent a few PAR rods in the process (Magnus rods)... thank goodness Manley has been suppying the new 162 mm rods for some time now with no issues.
I do agree however unless you really need to push the performance envelope - you do not NEED a 2.1l... but they are silky smooth and rev like mad.
Mike Huml
Slowboy -
Old Nov 10, 2008 | 09:15 AM
evovette's Avatar
Mike does manley also make a 156mm Rod so I can build my long rod 2.4?
Old Nov 10, 2008 | 09:23 AM
SBR INC's Avatar
Yes - only in an I beam right now... we are waiting on the H beam version!
Nice build - !!
Mike Huml
Slowboy -
Old Nov 10, 2008 | 10:08 AM
gt42r's Avatar
Stay away from par rods.I had them bent all 4 of them!!
Old Nov 10, 2008 | 12:27 PM
evovette's Avatar
Mike thanks for the reply. Im looking into Mahle pistons. I like light weight. Looking to do a nice 35R ( or some variant there of)street set up. I want 500-550 AWHP. Damn Porsche GT2 made me look bad!
Old Nov 10, 2008 | 12:29 PM
Billy@EnglishRacing's Avatar
The Magnus 2.1 is a very well built motor. If i was going to buy a built 2.1 that would be what i would buy.
Old Nov 10, 2008 | 12:58 PM
SBR INC's Avatar
I like Mahle as well - but I do not think they have an 87 mm bore stroker piston available unless it is something I have not seen before... (which is entirely possible)...
You going to run a stock bore 4G64 block (86.5) or .020" over (87)mm?
Mike Huml
Slowboy -
Old Nov 10, 2008 | 12:59 PM
SBR INC's Avatar
I bent all four as well - about three years ago... have not used any since.
I have never seen the Manley rods fail in this fashion - so I will stick with them!
Mike Huml
Slowboy -
Old Nov 10, 2008 | 01:11 PM
evovette's Avatar
The bore is dependent on what my machinist tells me. If I can get away with the stock bore, thats what I want. This is a street car above all else. Im also keeping the balance shafts in place for just this reason.
Old Nov 10, 2008 | 01:27 PM
ToMuchBoost's Avatar
Don't forget about jackson auto machine ..
Biggy VIII
Aug 9, 2016 03:06 PM
silentkiller
AEM EMS
Oct 12, 2014 08:00 PM
asubennett
Mar 15, 2012 07:22 AM
Mivec2.0
11
Dec 28, 2011 08:53 AM
lancerboy03
Lancer Engine Management / Tuning Forums
Apr 25, 2006 08:40 PM
