MIVEC swap onto non-MIVEC motor?
Old Mar 30, 2006 | 08:53 AM
lancerboy03's Avatar
Question MIVEC swap onto non-MIVEC motor?
question? want to know if there is any way u could put the MIVEC unit on a non MIVEC engine cuz i know u cant swap heads cuz its .4 bigger and that woundt work or would it ?
Old Apr 5, 2006 | 09:16 AM
Green_Bandit's Avatar
I HIGHLY doubt it...
Its not as simple as that, its also going to have to work with the ecu and alot of other good things...
Old Apr 6, 2006 | 08:03 AM
blaze_125's Avatar
ain't gonna happen.
Old Apr 6, 2006 | 04:19 PM
Tainted Winter's Avatar
The head is not where the extra .4 comes from. That is from cylinder displacment. ES have about 2000cc of displacement (1000cc = 1L) while the Rallyart has about 2400cc. So reall that means that each cylinder will only gain about 100cc. Long story short, not worth the labor, money, or time.
Old Apr 6, 2006 | 04:24 PM
If you where going to try anything crazy, try an Evo head swap. The change from single to double cam will give you a WHOLE lot more to work with (tunable cams and what not) To my understaning adjustable cams on a SOHC setup will either open the exaust or intake, not both. So your gains depend a lot more on your exaust system and/or intake.
But i give you props for trying, if enough people start to go tune-crazy... soon "they" will make us some creat engines...
Old Apr 7, 2006 | 09:16 AM
so u think some one could swap a SOCH to a DOCH is that possible? i was thinking that but i dont know if it will work has any one seen it done on a car any car ? but would i have to change my ECU and all to do some thing like that but i will still ask aroud thanks for the idea hope its possible
Old Apr 7, 2006 | 11:58 PM
my friend has a few DOHC heads laying around. ALOT of machining but the actual block is very similar. Someone should do a GSX DOHC motor swap....SWEET. With the ECU and right wiring I could see it working. Keep an eye out, someone is bound to do it. Or an 4G63 swap.
Old Apr 9, 2006 | 11:12 AM
yea tru hope i could well thanx
Old Apr 25, 2006 | 08:40 PM
phil_'s Avatar
dream on guys, lol
There is a mivec 4g92, quite rare, wonder if any possibilities lie there, though i believe its dohc
Any 4g6* head won't work, not possible, 4g9* is the series we need the head from, finding the head is the problem
Grimgrak
Apr 28, 2015 01:49 PM
shadow_X
May 4, 2013 09:49 PM
wickj_7399
Dec 5, 2012 11:18 AM
asubennett
Mar 15, 2012 07:22 AM
KooIDud3
Jan 27, 2008 06:11 PM
