FP Green to Red conversion
Old Nov 8, 2008 | 09:35 AM
tony gibson's Avatar
Originally Posted by Dr. SS
are you sure your green is bad? there is a normal amount of shaft play radially. axial shaft play is bad.
The play is axial or "in and out" and its about 1/8th to 1/4th of an inch...I've seen many turbos go bad, owned two evos and two dsms so I am pretty certain when a turbo is going to take a dump
Old Nov 9, 2008 | 10:11 AM
addo's Avatar
2months turn around for upgrading std IX turbo to red, do you have the same unit back just upgraded or is it like buschur exchange basis on the his manifolds where he has them ready and just receives yours and sends out a previously modded one?
Old Nov 9, 2008 | 06:37 PM
Thats a good question....I suppose mine would be like building a IX turbo into a red...they may have to haug the compressor side some more for the red wheel..not sure. I hope they can turn it quicker than 2 months but I supose it will be worth the wait. No biggy anyways since I have other stuff to do to the car anyways.
Old Nov 9, 2008 | 08:01 PM
Shacochis06's Avatar
im sure you get your core back....trust me the red is worth the wait
Old Nov 10, 2008 | 12:55 AM
Q8_EVO's Avatar
Do it Tony!
does edwin still have his evo 8 LOL
Old Nov 10, 2008 | 09:21 AM
zedevo's Avatar
Guys , i received the green from 1 month ago ... He's still in the box, then i heard about the RED... What is the REAL Difference between the RED AND THE GREEN ??
can i exhange him to the red , cause the green is still bran new ... with all the options ...
I u guys were in my place what did u do ???
Ill Suggest to wait little bit to see what is the good and bad effect of the RED, I have a BRAND NEW green still in the box with all the options as 18PSI , Ported & C.COATED, Install kit etc ...
Any way I can understand well that the RED is the same as the GREEN on PUMP GAS but the RED work very hard and strong ON RACE GAS ... Hope if some prove that im wrong ... Hope that ill not desapointed for buying the GREEN ...
THX GUYS
thx a lot for ur HELP ....
Old Nov 22, 2008 | 08:02 AM
Levar's Avatar
Veteran: Army
can i exhange him to the red , cause the green is still bran new ... with all the options ... I u guys were in my place what did u do ???
Ill Suggest to wait little bit to see what is the good and bad effect of the RED, I have a BRAND NEW green still in the box with all the options as 18PSI , Ported & C.COATED, Install kit etc ... Any way I can understand well that the RED is the same as the GREEN on PUMP GAS but the RED work very hard and strong ON RACE GAS ... Hope if some prove that im wrong ... Hope that ill not desapointed for buying the GREEN ... THX GUYS thx a lot for ur HELP ....
Bottom Line, you might have to send the Green back to FP for their $1100 conversion considering the stark differences between the Green and Red. I've been looking for a Green with all of the bells and whistles and would entertain buying yours if you choose a different direction.
Old Nov 22, 2008 | 08:22 AM
zedevo's Avatar
Thx for ur advice .. keep u in touch man ...
Old Nov 22, 2008 | 09:19 AM
Levar's Avatar
Veteran: Army
So that I'm 100% sure...
FP will convert either a stock IX turbo or a Green to the Red for $1,100, right? Does this same concept apply to a stock VIII turbo? I'm thinking that it doesn't but it is better to ask for clarification.
Old Nov 22, 2008 | 10:30 AM
zedevo's Avatar
I called FP They told me : AS ur turbo is still 100% NEW in the box with install kit and with all the options AS 10.5 HOTSIDE, 18PSI W.G, PORTED AND COATED etc .. they reduce 25% from the price and they give the red but afetr my research the green is the same ON PUMP GAS as red BUT THE Advantage of the RED that he can reach over 500bhp on race gas...
Old Nov 22, 2008 | 12:34 PM
Yeah I will be running e85 so that is the main reason I want the red...may tune it for q16 as well and see if it gains over e85..if not, my tank will always see e85. I believe mine is already ported but i will have fp look into that when I send it and if its not I will have that done as well. I have the 18psi wga already..just need to finish my headgasket and timing belt and send this bad ride off to Texas!
Old Nov 22, 2008 | 12:46 PM
zedevo's Avatar
+1
Old Nov 24, 2008 | 04:15 AM
Levar's Avatar
Veteran: Army
I'm just curious about these two questions before I make a wasted purchase. Thanks.
Old Nov 24, 2008 | 06:40 AM
batty200's Avatar
It doesnt matter if it is a Green or a stock 9 turbo it is 1100 bux and an 8 turbo will not work. If it would I would have a red right now.
Later
Old Nov 24, 2008 | 04:38 PM
Levar's Avatar
Veteran: Army
^ Good information to know. It is useful to me due to a comparison of the new BBK turbos. Thanks.
foxracing515151
Aug 8, 2014 06:32 PM
High_PSI
Oct 28, 2013 01:56 PM
EyeDreamt
30
Oct 31, 2011 11:44 AM
2Fst4U
Evo X Dyno Results
54
Aug 24, 2010 02:09 PM
