8 to 9 turbo swap. Did i do wrong?
Old Nov 9, 2008 | 06:53 PM
YNGEVO's Avatar
Hey guys. i have an 03 evo 8 and just swapped the evo 9 turbo. Am i supposed to use the stock evo 8 oil/water lines or do i need to use the evo 9 oil/water lines? Thanks. The only reason i ask is because the upper oil line that goes into the head- the part where it bolts in- that holes threads got stripped. So now i have to take a helacoil to it to re-thread it.
Old Nov 9, 2008 | 06:57 PM
bluebanana23's Avatar
most buy the install kit but you can just bend the viii lines to work. I'm still using the stock lines with no probs.
Old Nov 9, 2008 | 07:00 PM
YNGEVO's Avatar
i have all lines from an 8 turbo and a 9 turbo. But which one do i use for the 9 turbo on an evo 8 motor?
Old Nov 9, 2008 | 07:01 PM
wevo1985's Avatar
use the lines from the 9 turbo.
Old Dec 6, 2008 | 10:53 PM
skags's Avatar
i just bought a 9 turbo to go on my 7 , the guy is seeing if he can still get the oil and water lines, would it be worth getting them or buying the 8 to 9 kit ? or is the kit pretty much the 9 lines anyway ? any help appreciated thanks
Old Dec 7, 2008 | 07:05 AM
Evo8Emperor's Avatar
On my swap I still used the stock evo 8 lines for the 9 turbo no problem. As long as you take your time and dont wrench on them you can bend them to your likely easily. Just less money to spend on un-needed things.
Old Dec 7, 2008 | 07:15 AM
TTP Engineering's Avatar
You have to use the 9 turbo outlet pipe or else you will blow up your battery when the starter ARCs against the Evo 8 outlet pipe.
Old Dec 7, 2008 | 07:18 AM
tkklemann's Avatar
Yes, that's the only part you really HAVE to have. All of the lines fit up with some minor persuasion. (ie. bending them)
Old Dec 7, 2008 | 03:30 PM
sparky's Avatar
Originally Posted by YNGEVO
.... the upper oil line that goes into the head- the part where it bolts in- that holes threads got stripped. So now i have to take a helacoil to it to re-thread it.
How far in is the bolthole stripped? Are you sure that itīs the internal threads and not just the bolt thatīs stripped?
Old Dec 7, 2008 | 03:43 PM
dirtyrican08's Avatar
We fixed his Evo already
Blanco
RacerX-Ralliart
195
Mar 15, 2021 04:16 PM
FilthyEvo
Jul 25, 2016 09:18 AM
MisUnderStood
18
Nov 29, 2015 08:16 PM
stunt2
Nov 27, 2012 12:10 PM
madman
Sep 3, 2003 09:13 PM
