Big Turbo Guys how much timing are you running.
Old Nov 16, 2008 | 01:05 AM
  #46
Whoop_ass's Avatar
Originally Posted by JohnBradley
FID,
MBT is not variable based on fuel. MBT is based on engine dynamics. When you assert that you reached MBT on pumpgas on your VR6 at 22 and then 30 on racegas what you did is discovered that MBT is actually 30* and on pumpgas you cant reach it.
Evos with a standard bore, no headwork, and standard compression run into this somewhere around 19-20*. Altering the VE and efficiency of the combustion chamber will alter this as well, but not to a large degree. Overall bore size has far more to do with timing advance vs. MBT than anything. Larger bores need more time to combust fuel so more advance will work (i.e. Subaru 92 & 99.5mm bore, Small blocks, Big blocks, etc.). The only time fuel dictates timing that I have ever seen is either Methanol or Nitromethane and thats a completely different ballgame.
now that is interesting info...
never knew timing played a role on bore, and makes sense that a engine with a higher VE can run more timing as it is dealing with flow better...
some nice posts in here...
Old Nov 16, 2008 | 01:14 AM
  #47
RazorLab's Avatar
Originally Posted by fid
No, I understand. I am not trying to say every engine has a single MBT number and then that is it. I am trying to say there is a MBT for a engine that is knock limited and there is a MBT number for that same engine when it is not knock limited.
You either don't understand MBT or where taught a different meaning of MBT if you think that statement is correct.
Absolutely no way you are hitting MBT on American pump gas (94 or less) on a Evo.
Fuels that you can go up to and even beyond the engines MBT are fuels like VP import and E85. You hit MBT when adding timing makes no power increase. With pump fuel, you will always hit knock before you reach MBT, and the knock is what is preventing you from making power increases. Try turning off the knock sensor on pump gas on a Evo and see if you can hit MBT before you hear detonation.
Like JB said, on pump gas you are not hitting engine MBT but the limitation of that octane.
btw this is a great thread.
Old Nov 16, 2008 | 03:41 AM
  #48
EE's Avatar
EE
FID,
John, when you say the limit is 19-20*, on which rpm is this??
Tks
Old Nov 16, 2008 | 05:20 AM
  #49
Mellon Racing's Avatar
here we go again with people trying to nail down a specific degree of timing to a specific RPM...seriously people quit trying to copy other peoples tunes and either figure out what YOUR car likes or get it professionally tuned. It's been stated in her many times now
1 - each car is different due to mods/boost/octane/altitude/compression etc...
2 - you're going to knock well before you reach maximum timing on pump gas
hate to be rude but we're going in circles
Old Nov 16, 2008 | 06:28 AM
  #50
JohnBradley's Avatar
Tks
Assuming that fuel isnt a constraint you will see 19-20* by peak power + a few hundred rpm for your particular combo, somewhere north of 7,000 usually. If you are on a fuel that you cant reach or surpass MBT, then as Mellon said its whenever you hit scattered knock.
Old Nov 16, 2008 | 10:01 AM
  #51
Whoop_ass's Avatar
Ye we understand Mellon but....
if you had 2 of the same cars with same mods , we not saying they will be identical but they will be close, within 1-3 degrees of each other, each car is different.
And they all act different, hence why we tune them.Take Bushcur, I am sure he has base maps set that he later on tweaks to the cars liking but he has an idea what he feels the limits of 93 would be with his stage 3 builds on pump gas.
I just asked what timing are people running on 93 with big turbo cars.
big turbo cars can carry more boost at redline and don't fall off like the stocker and maybe that is why you wont run big timing @ redline with say a 35R compared to the stock turbo.
Also big turbo cars have a way cooler charge temp than a stock turbo and that is why you can run 30 psi on 93-94 octane with out knock.
you not gonna run 30psi with the stock turbo on pump.....you use meth to increase octane and to cool charge down.
With VP import on the stock Turbo I have seen timing of 15 deg at peak torque and maybe even 35 deg @ redline. now the turbo becomes the limit and you will prob get to the point were adding more timing won't net any more power.
Mellon you have tuned a couple of big turbo cars.
share with us your timing expirences.
Old Nov 17, 2008 | 03:24 AM
  #52
EE's Avatar
EE
Yeah I know on regular fuel I'll be hitting knock before reaching MBT, I was just asking abt the MBT itself. The reason i asked for this is bcs i hv never tuned my car on anything else than 98Ron (equ. to 93), so it's nice to have an idea abt the timing you can / should run on race gas... Tks for sharing info John
Mikeshkap13786
Mar 1, 2017 08:46 PM
moey124
Nov 3, 2015 08:35 AM
David Buschur
34
Jan 26, 2009 09:25 AM
inariv5573
May 13, 2005 06:48 AM
EVOnoir
10
May 1, 2005 08:43 PM
