need help with my Exedy hyper single
Old Nov 15, 2008 | 05:57 AM
Jester''s Avatar
after 3k on the clock and 4 launches, im having a hard time slotting into first and reverse gear, especially early in the morning, or after a long stop. i have to slot into the other gears first (third and fourth mostly) before ill be able to slot into either first or reverse.
i sent the car to a reputable workshop and the mechanic had my pedal clutch adjusted to a higher degree. initially everything was clockwork, but now the problem with slotting into reverse is coming back. slotting into first is alright though, but my gut feeling says the problem will resurface.
i didnt have this problem with stock clutch, or the Exedy when it was first installed. can you guys help?
Old Nov 15, 2008 | 06:00 AM
Jester''s Avatar
those who are using the hyper single, please share your experience with this kind of clutch. id really appreciate it. thanks in advance
Old Nov 15, 2008 | 08:29 PM
Jester''s Avatar
bump
Old Nov 16, 2008 | 10:50 PM
Jester''s Avatar
aww come on you guys, i cant be the only one having this problem
Rumblefish237
16
Sep 1, 2011 02:26 PM
Braden71790
Apr 7, 2011 12:51 PM
pensport
Sep 7, 2009 09:53 AM
haze1995
13
Nov 19, 2006 09:19 AM
Smoothgangsta
May 10, 2005 11:21 AM
