FPRed or BBK or Meth
Old Dec 16, 2008 | 01:58 PM
  #31
ch53avitech's Avatar
You can never go wrong with the Red and meth, on the street and on the track.
Old Dec 17, 2008 | 05:51 PM
  #32
prostcj's Avatar
Originally Posted by SRT-TO-EVO
Umm can you read? Here let me help you out. https://www.evolutionm.net/forums/ev...-thread-8.html
NOW when the BBK is CONSISTENTLY time and time again putting out numbers 430+WHP, then compare the two. To this day ONE person with a BBK barely (Kreionic) broke 400. BTW those are on PUMP. On E85 which is also considered "pump" in many areas it becomes an obliteration.
Ok,
Now compare those results to FP RED's on the same CBRD mustang dyno.....not to dynojet plots.
Try the BBK dyno results thread.
Old Dec 17, 2008 | 06:12 PM
  #33
SRT-TO-EVO's Avatar
Originally Posted by prostcj
Ok,
Try the BBK dyno results thread genius.
Ok wise guy are you talking about the ONE red that was dynoed on it? I thought so. I will say it again know-it-all, please refer to RED dyno thread (and CBRD's own comments if it makes you feel better).
Old Dec 17, 2008 | 06:24 PM
  #34
Shacochis06's Avatar
I have been the only Red dynod on CBRD to date....i still did 379/313 with a stock IC.....in the middle of August
on the dyno day with a lil more boost it did well over 420...
and i was the first reds on pump gas and CBRD was one of the first ones to tune a red on pump...this was dynod way back in august....i gurantee if i dynod now i could do very close to 400 with same mods...seems like all the bbk have been dynod in alot cooler weather so im sure the weather is being generous...not knocking the bbk turbo just saying i think the weather is being genrous
with just a BR IC i think it well put me over 400 easily in 80 degree weather and over 400 is a major accomplishment on this dyno
Old Dec 17, 2008 | 06:57 PM
  #35
prostcj's Avatar
Relax, I see you bought a FP Red. No one's peeing in your cheerios. The Red Dyno is proven. The BBK is not....but so far all the BBK plots made by CBRD are comparable or better to the one Red tested and the various 30R plots posted. In fact, people showed overlays of the BBK vs. the 30R's on pump. If you look at the one red dynoed on the CBRD dyno it looked like it had about the same shape and peaks as the BBK. (this would be an argument for the Red)
I don't think anyone thinks the BBK can match the Red on E85.
If you would bother to read all the posts I have made I'm trying to choose between the Red and the BBK and I'm waiting for other tuners to comment on the BBK.
So...as it stands now the two turbos look like they can be compared to each other on 93.....
I understand that both turbos will be great so no need to say that again.
Old Dec 17, 2008 | 07:01 PM
  #36
prostcj's Avatar
Oh, and I'm buying a Red BTW so relax, everyone is so uptight.
Old Dec 17, 2008 | 07:47 PM
  #37
CBRD's Avatar
oh here we go
lol..
pm me if you want our info. if you buy a red im sure it will work well for you.
cb
Old Dec 17, 2008 | 11:03 PM
  #38
Cali2MDevo8's Avatar
Registered User
Did you happen to get an IC yet?? I would like to see your RED on CBRD's dyno again with an IC. I personally feel the red NEEDS meth/alky or E85.
Old Dec 17, 2008 | 11:14 PM
  #39
Yup i did....i wana see what gains are from just bolting it on....Charlies coming up soon i hope to have a cpl other things to get done while hes here....
Im to scared of meth/alky and have no way of getting E85....i well do some Q16 for sure tho if i come up...
is there any E85 stations anywhere near CBRD or anywhere close in PA?
Old Dec 17, 2008 | 11:17 PM
  #40
Registered User
E85 is close to CBRD. Do you have large enough injectors??
Old Dec 17, 2008 | 11:29 PM
  #41
No not at all...
Never really liked the idea of using corn for fuel...but then seeing results and the actual price of it i guess it cant be beat and is a better way to go instead of VP fuels...
PM me details of where its at up there
Old Dec 18, 2008 | 06:31 AM
  #42
prostcj's Avatar
http://www.e85refueling.com/distance.php?page=1
Old Dec 18, 2008 | 08:12 AM
  #43
drop24's Avatar
I've decided to go with the BBK since I don't want to run meth and we don't have E85 here. Hoping to do my build soon. Adding FMIC, S1 Cams, 02 Housing, Injectors, and Headstuds at the same time.
Old Dec 18, 2008 | 04:44 PM
  #44
Registered User
Do the S2's man. I'm regretting not doing them now
Old Dec 18, 2008 | 05:37 PM
  #45
drop24's Avatar
Thinking about the S2's. I'm worried I won't like the idle.
