FP RED dyno results thread
Old Dec 8, 2008 | 04:52 PM
  #106
Levar's Avatar
Veteran: Army
Originally Posted by brodienuchies
4200 doesn't seem too bad. Doesn't GREEN reach full boost by 3900-4000?
I'm not trying to get into a technical debate and hijack the thread. I'm simply saying (comparing) that if the Green does in fact hit full boost at 4000 and the Red just shy of that. The Red seems like the winner overall considering that it flows roughly 60-lbs/min vs. the 47-lbs/min that the Green offers. Even when it comes to other stock-like turbos, that reach full boost (set roughly at 27PSI) around 3400 or so, I personally don't believe that a mere 800 or so RPM would equate for any other stock-framed turbos to be supreme than the Red. These are just my thoughts.
Old Dec 8, 2008 | 05:11 PM
  #107
Levar's Avatar
Veteran: Army
Originally Posted by Evo H8
You would be pushing the limits of your fuel system. 1200CC injectors and two fuel pumps is ideal for FP Red on E-85 at the 30psi sweet spot.
That is the same that I've read on various threads. E85 changes the whole equation. An option with E85 is not to run that 30PSI sweet spot but then why run E85 in the first place? I, personally do not want to have to buy the double pumper right off and I might hold off on making the E85 conversion and have the potential on-tap until the time is right.
Old Dec 9, 2008 | 11:03 AM
  #108
purevibez's Avatar
M2's, ported IM-TB, ported EM, 26psi on 93 pump, single 255, conservative tune,1000cc, full bolt ons, 3.5 IC, epm o2 dump
Old Dec 9, 2008 | 12:25 PM
  #109
Q@EvoPowerMods's Avatar
Oh yes...sweet numberz....
Old Dec 9, 2008 | 12:41 PM
  #110
purevibez's Avatar
thank you sir
Old Dec 9, 2008 | 01:53 PM
  #111
localtoys73's Avatar
i wish santa would bring me a red or a green for x mas...ahh
Old Dec 9, 2008 | 04:48 PM
  #112
Levar's Avatar
Veteran: Army
I like what you put down particularly around the 7K mark as I usually stay around 6900-7200 when shifting. I plan on comparing your graph to see where (if at all) my optimum shift points would change to.
Old Dec 9, 2008 | 05:04 PM
  #113
purevibez's Avatar
cool man no prob
Old Dec 15, 2008 | 06:42 AM
  #114
purevibez's Avatar
here is the E85 graph. same mods as before but E85 at 30 psi
Old Dec 15, 2008 | 07:21 AM
  #115
matt55's Avatar
Originally Posted by El.BlueEvo9
Mine is on my sig....."JestRTuning & BigValleyPerformance
FP/Red
466.79WHP/393.90TQ -93 Octane No Meth
http://i189.photobucket.com/albums/z...p/MannyRed.jpg
And Thanx "04AWDTURBOEVO" For All Of Your help =)"
-Manny-
.........93 octane no meth stock cams and gears, @27psi...........Awsome turbo, still holding 450+ at 7800
B.M.F. with stock cams and 93 octane !!!
Old Dec 16, 2008 | 08:18 AM
  #116
El.BlueEvo9's Avatar
Yes sir..
Old Dec 16, 2008 | 08:26 AM
  #117
"edit" repost
Old Dec 16, 2008 | 09:20 AM
  #118
JohnBradley's Avatar
https://www.evolutionm.net/forums/ev...p-red-e85.html
Old Dec 16, 2008 | 09:59 AM
  #119
BlueDemon's Avatar
I'm going to try to post my graph today guys!
Old Dec 16, 2008 | 10:40 AM
  #120
Shacochis06's Avatar
FP Power....
over 6,00 views of this thread....
