Oil leak or Busted CV Joint
Old Nov 24, 2008 | 01:30 PM
def1's Avatar
Everytime I come home there is brown fluid leaking beneath the oil filter. Just like a few drops a day. Ive replaced two filters already and still not working so i dont think it is that. All the lines dont seem to be leaking but they are full of grease. The grease is all over the place from the oil filter all the way to the inner cv joint and also to the transfer case. My oil dipstick level is always in the same place. I was cleaning it today as I was looking for the cause of the leak and the stuff is really thick grease and its dark dark black. And the inner cv joint drips as well so Im thinking it is the cause.
One more thing I took my car to get the timing belt done and one of the bolts above the oil filter (small bolt 12 mm) does not tighten all the way. I think they may have stripped it but I dont think thats the cause of the leak but maybe you can inform me otherwise.
thanks guys =]
Old Nov 24, 2008 | 05:04 PM
STiHAVOK's Avatar
can you see the hole in the cv boot?
Jeff_Jeske's Avatar
Could be both but one thing is for sure, there shouldn't be grease everywhere. That would be a ruptured CV boot.
If the boot is bad but not yet contaminated you can simply fix it with a universal boot.
Once repaired, wipe everything down and spray it off with brake parts cleaner. Then trace the source of the oil.
Old Nov 24, 2008 | 05:19 PM
Aman's Avatar
check ur rack . poke a hole in rack boot to see if it leaking...
Old Nov 24, 2008 | 06:20 PM
Kracka's Avatar
Umm what?
Hey, does that pail hold water? Hmmm, not sure, let me drill a hole in it and find out. LOL
Old Nov 24, 2008 | 06:50 PM
Aman's Avatar
Originally Posted by S2kracka
Umm what?
Rack and Pinion <<<<<<<<<<<<< ummmmmm does ur evo have one ???????????
Logie888
Sep 27, 2013 04:52 PM
AWDTerror
46
Feb 14, 2013 08:21 AM
bolc
Lancer Tranny/Drivetrain Tech
10
Feb 6, 2012 04:43 AM
Adam@MMS
May 8, 2008 09:52 AM
vampeer
Dec 8, 2006 11:37 AM
