Exhaust Manifold ?'s
Old Nov 26, 2008 | 01:19 AM
SlowEvo-IX's Avatar
Hey guys I'm about to remove my exhaust manifold and I was wondering if you guys have any tricks in removing it. What did you guys do to break the nuts loose? (PB blaster? Breaker bar? Or just plain muscle? Did you use anti-seize?) And how did you guys get to the bottom bolts on the exhaust manifold that connects to the head? I cant even see them lol. Thanks guys
Old Nov 26, 2008 | 02:04 AM
jdm4g63tgalant's Avatar
Pb blaster and breaker bar...
as far as the bottom nuts on the mani...you'll have fun with that.
Old Nov 26, 2008 | 03:08 AM
SlowEvo-IX's Avatar
ha ha anyone else want to chime in? Regarding how you reach the bottom nuts?
Old Nov 26, 2008 | 03:09 AM
SlowEvo-IX's Avatar
Old Nov 26, 2008 | 03:47 AM
meckert's Avatar
use an extention and deepwells, you can reach them all and its simple.
Old Nov 26, 2008 | 07:46 AM
travman's Avatar
PB blast the *** out of it - mine all broke free with minimal effort @ 30k miles when I did my ported goods. I replaced studs with SS hardware to help future removal much easier
Old Nov 26, 2008 | 08:04 AM
4G63K's Avatar
not to sound like a noob but whats a pb blaster?
Old Nov 26, 2008 | 08:09 AM
baylorar's Avatar
aerosol can of stuff that gets rusty bolts to break loose. very handy when taking mani/hotside/02 housing stuff off.
Old Nov 26, 2008 | 08:22 AM
EvoDom's Avatar
u need pb blaster and a swivel socket for the bottom ones. use your muscle
Old Nov 26, 2008 | 08:28 AM
DDATuned's Avatar
uhh un zip your pants , reach down....
Old Nov 26, 2008 | 08:54 AM
travman's Avatar
that could be the ultimate noob question ever....
PB blaster was sent from heaven, it is only the greatest thing known to man to come from an aerosol can.
11th commandment - "Thou shall not work on a car without a can of PB Blaster"
Old Nov 26, 2008 | 08:59 AM
prodystopian's Avatar
Is there much of a boost when replacing the EM or is the stock one pretty good for a stock turbo?
Old Nov 26, 2008 | 09:07 AM
travman's Avatar
ported stocker - done.
Old Nov 26, 2008 | 09:25 AM
chaotichoax's Avatar
wd-40 on roids
Old Nov 26, 2008 | 10:09 AM
Evoryder's Avatar
For tools I went to Sears purchased a short 12mm,13mm, and 14mm socket(3/8") swivel adapter pieces, comes in a set of 3. Set of 3 socket extension(3/8), short,medium and long. Pivoting socket wrench. The bolts on the bottom are not hard to reach, they look it though. Make sure you have a sheet of cardboard on the radiator.
My bolts had 65k on them, broke 1 stud, and 3 studs came out as a 1 piece with the nut. Replaced all but 2 stud/nut combo's with grade 9.8 bolts to make life easier in the future.
