Boost controller question plz help
Old Sep 8, 2003 | 10:14 AM
XRS-Lift's Avatar
Hey i am considering getting a turbo XS high performance mechanical boost controller. I want to raise my boost to 20psi and keep it there all the way to redline. I was wondering if i used this mechanical boost controller to set the boost to 20 psi, would it drop to 17 psi as the rpms go up? Or will it stay at a constant 20 psi. Cuz i know the stock boost drops from 19.5 to about 16.5.
If this controller wont do what i want, anyone know of a mechanical controller that will? I dont want to spend hundreds on a electronic one.
Any help would be GREATLY appretiated.
Old Sep 8, 2003 | 10:22 AM
mrdecibel's Avatar
If you set it at 20 it will stay close to that. The factory has an active boost controller. The XS is passive.
Old Sep 8, 2003 | 10:29 AM
XRS-Lift's Avatar
WOhoo!! Thanks! By the way, is this the best mechanical boost controller i can get if i just want to set it once and keep it there?
Old Sep 8, 2003 | 10:31 AM
mrdecibel's Avatar
They are practically all the same when dealing with ball spring type.
Old Sep 8, 2003 | 10:41 AM
XRS-Lift's Avatar
great thanks a lot. Anyone know where i can order one of these for cheap?
Old Sep 8, 2003 | 12:41 PM
berkel's Avatar
I have a Hallman. First one I ever installed and it works well. You can also add capability to tune it from within the car, pretty cool.
BTW, you may should keep tabs on it, since boost will change somewhat with diff weather, elevation, etc. You may have to adjust it from time to time, and obviously need a boost gauge.
Good luck!
FB
Old Sep 8, 2003 | 12:50 PM
1QWKEVO's Avatar
better get some octane in that car if you plan on running 20psi daily..... or you can start saving for a new motor, one or the other
Old Sep 8, 2003 | 03:07 PM
XRS-Lift's Avatar
im running 91 octane right now. Best i can get my hands on. Should i invest in some octane boosters? If so, which ones? Also if the car is running 19.5 psi stock on 91 octane i dont think 0.5 extra boost would hurt.
Old Sep 8, 2003 | 03:09 PM
tx evo's Avatar
You will be fine with 20 psi , on 91 octane.
Old Sep 8, 2003 | 03:11 PM
XRS-Lift's Avatar
hell ya, good to know. Thanks.
redaplatr
Mar 23, 2017 12:58 PM
v8k1ller
Apr 20, 2007 09:32 PM
osunick
May 6, 2005 06:39 AM
EvilDylan
14
Nov 10, 2004 07:31 AM
Bobby12many
13
Aug 30, 2004 05:31 AM
