rear diff oil change= huge mess/picts :mad:
just have the dealer do it they charge $65, and if your paranoid just buy oem fluids from online and have tech use it. most cases my local dealer have oem trena,t-case fluids etc
I've never seen so much crap come off of my drain plugs as when I used to use Redline or Amsoil. Consequently my transfer case blew shortly after I became one of the Amsoil loyalists. Best thing I've found is OEM super diaqueen 6spd fluid for the tranny, both 5spd and 6spd. They loaded it down with a ton of additives for the weaker 6spds and it works amazingly in our 5spds. OEM diaqueen LSD for limited slip transfer cases and rear lsd's. For '03/'04 open diff transfer cases the OEM 5spd tranny fluid is what is recommended from factory. You may have to just go to your dealer with your own container and ask them to fill it up for you. $25 is the going price for a gallon on the side
One thing I am looking at.... 2 qt bottles a funnel and a hose... and all I saw mention of is changing the rear diff which only holds 1.2 Pints..
Everyone thinks that filling to the edge of the hole is proper fill height where in most cases, it is below that.
Overfilling can cause seal damage..
Doc
Doc
Team Rip (http://www.teamrip.com/faq.htm)
Jack Stands or Race Ramps (http://www.raceramps.com/) plus pump
FTMFW
FTMFW
Right from Team Rips website:
There are concerns about using Redline's Shockproof type gear oils inside manual transmissions. While this is truly an excellent product, it has been found that the heavy paraffin-like particles are quickly centrifuged out of the oil and build up inside the center diff housing and around the synchronizers and inside of the gearshafts. After several oil changes this build up may block oiling passages inside the gearshafts that lubricate the needle bearings and can reduce the overall effectiveness of the synchronizers, leading to poor shift quality. Therefore we do not suggest using Shockproof in the transmission unless the transmission is to be serviced often or a dog box.
Amsoil offers an excellent manual transmission gear oil called Manual Transmission Gear lube or (MTG) that is a 75w-90 API GL-4 oil and it will work very well in your transmission.
Doc
For those of you who are looking for a simple way to get fluid back into your transmission, transfer case, or rear end, I've found that a suction gun works VERY well.
http://www.tooltopia.com/index.asp?P...utm_medium=PPC
You can find them at most NAPAs or similar stores. I get a smaller gauge clear hose in addition to the one that comes with the suction gun, so it will fit the smaller fill holes.
I measure the new fluid in one of those graduated plastic paint containers ($0.99 at the hardware store) and just suck it up with the suction gun and push it right into the diff or rear or tranny. Clean, right amount, and done in no time...
TTP (Scott) iam sure at this point in time alot of these oils are very competitive, however its seems like OEM in the diffs and MTG in the tranny is paying off for the public
Anyone got any tips for getting the left over fluid out of the containers?
For the stock to mildly modified Evo's, OEM fluids work.
For the higher torque output Evo's, the additional protection of heavy shock is a +.
Last time I spoke to Shep, he actually stated that some people are actually having great success using the heavy shockproof redline in the transmission.
I was scratching my head on that one, but if you find something that works well for you, that is what is important.
As mentioned in TRE's Website, they are finding what they have been calling a "Waxy Buildup" in the trannies using Heavy Shockproof. Redline uses a tackifier and this appears to be the Polymers (plastic) being centrifuged out.
This will be of concern as it builds where it will cause tempuratures to rise and possibly poor shifts over time.
Doc
I've used a mix of heavy shock and mt90 in the evo for about the last 15k (2 fluid changes already due to a number of track days). I personally don't have any complaints, better than the factory crap that was in there. I have not tried the diaqueen 6-speed fluid yet though.
lockadam2112
For Sale - Miscellaneous Automotive
Feb 22, 2011 10:49 PM
