What causes High RPM lockout on ACT clutches?
Old Oct 25, 2010 | 11:13 AM
  #76
fugiwara's Avatar
Anyone that had Lockout with ACT and have found out why it was locking out please share your findings.
Old Oct 25, 2010 | 07:28 PM
  #77
bigturboevo80's Avatar
I have lockout issues when I shift real fast at around 8500 rpms trying to go into 4th gear. I dont know why. My clutch pedal is adjusted all the way out. My clutch was done through a shop that works on lots of evos all the time. And they know what their doing.
Old Oct 25, 2010 | 09:04 PM
  #78
fightex's Avatar
my ACT HDSS used to lock me out all the time. changing the tranny oil to Amsoil AT4 gear lube made a significant difference. then adjusting the clutch rod seen in this thread cured most of the notchniess both cold and warm! its a must try for anybody experiencing reluctance in their shifter.
i put off checking the rod for the longest time because the clutch was installed by a very well known shop, so i took their work for granted. when i finally got sick of lockouts and scratching gears (not to be mistaken with misshifting - as i had experimented with keeping my foot planted on the clutch and holding it their during high rpm shifts, yet it still scratches or get locked out at high rpm), i found that the rod was very short, even though the engagement was in the middle.
i just wish i'd stumbled across clutch adjustment threads sooner because i'm fairly sure the 4th gear syncro had been taking a beating, to a point where it'll need replacing before i can swift gear changes again
Old Oct 27, 2010 | 09:55 PM
  #79
sunrichmond's Avatar
lol he just answer your guys question, i used honda high temp grease for the shaft, works great
06RedRalli
Dec 8, 2015 07:05 PM
PHILLY EVO
Jan 25, 2015 05:48 PM
meric
Sep 3, 2014 06:40 AM
Robertv34
24
Sep 7, 2011 07:23 AM
