Larger hotside for Stock, Green, Red???
Old Dec 3, 2008 | 10:41 AM
rr06rs's Avatar
Originally Posted by Steve93Talon
One word - MONEY. It costs tens of thousands of dollars to tool up a casting and put it into production, and that's not counting designing it. It takes awhile for the market to mature to the point where it's going to be profitable for someone like FP to start making their own housings. As I said, the DSM crowd used the standard 16g style 7cm housings on 20g, Frank series, Green, and Red (some Reds used 8cm housings) for a looong time before the vendors saw enough demand for a custom casting.
I don't think it'll take as long in the EVO world, there's already a built in market for big power turbos that'll bolt on, but the question is how many? Let's say a Red style turbo with a custom cast bolt-on housing costs $2299 (assuming $500 over what the Red costs for the cast housing), you're getting nearer to what a T3 style kit costs. As for something to use on a stock turbo, there's already the 10.5 hotside, which is probably about the point of diminishing returns for a 16g wheel. If a custom hotside cost $500, I'd sooner put that money into a BBK lite or FPWhite conversion.
I think if FP were to chime in, they wouldn't offer anything in terms of what they're working on anyway. If they already have a project like this in the works, the last thing they want is to have a new thread every day bashing FP for taking too long. They also wouldn't want their competitors to find out what they're up to.
I dunno.....even a 10.5 housing is DAMN tiny. I think there is room for improvement. I would consider doing something like extrude honing if I thought there was a way to do it without damaging the area that the turbine wheel protrudes into but I don't know if it could be done without damaging it and causing exhaust to leak by the wheel? Anyone had a housing extrude honed before?
Old Dec 4, 2008 | 11:52 AM
9sec9's Avatar
Originally Posted by ForcedPerformance
the standard non ported housing looks different in the turbine outlet now. We added a CNC mill stage to the process where it goes in and adds a big long smooth outlet instead of that little ridge, about 50% of the outlet is now CNC machined in a long smooth radius in the CNC mill. So even the non ported ones are partially CNC ported.
We also now offer a full ported housing option that is more than the early "gasket match" job we offered in the begining, there are pics of it here:
http://store.forcedperformance.net/m...=Turbo-Porting
On the topic of larger turbine housings from MHI, there are not any larger than the 10.5cm2 . MHI made 9.0, 9.8 and 10.5 only, then they stopped making the car so MHI stopped making parts
Robert, good idea on the deep CNC porting. I wish you had done that BEFORE I had to do it myself. I'm certain that you picked up some power on the Red by doing that. Does that mean my housing is now a collectors item? Anything new in the works? You can tell it here, nobodies going to tell.
Old Dec 4, 2008 | 01:03 PM
scheides's Avatar
EvoM Moderator
9sec9, beautiful port work as always!
And beautiful as well! Is that the $100 port job listed as an option for the FP RED, or a more expensive service?
Old Dec 4, 2008 | 01:18 PM
C6C6CH3vo's Avatar
I could never find anything larger than a 10.5 for my 16G. None exist possibly.
It would be impossible to properly increase the cm² on a 10.5cm² housing, if you could you would end up exceeding the thickness of the scrolls anyway. Mild porting will deffinately help though.
Anyhow, with the red (or even green) there really isn't a real reason to go higher than 10.5cm² with porting. But if your running the stock turbo and your trying to pick up the HP there certainly is.
Old Dec 4, 2008 | 01:35 PM
2highpsi's Avatar
Originally Posted by rr06rs
BUT.....why DON'T we start pushing the envelope.
Mid 9s on a stock frame turbo isn't "pushing the envelope"?
I am all for better parts, but I don't think everyone realizes the leaps and bounds that have already been made with these cars this year.
Old Dec 4, 2008 | 03:05 PM
AFI Turbo's Avatar
I would guess at some point all the turbo's would benefit from a larger housing to some extent, but only to a certain market.
Im not the biggest fan or stuffing big wheels into small housings, but i'll admit the Red seems to be working great, excited to get mine on my car
Has anyone logged back pressure on this unit yet?
I have 2 tubular headers (one 1.25" primaries, the other 1.5" primaries) i will be testing along with the stock manifold very soon...just wish i had a more capable ecu
Old Dec 8, 2008 | 08:18 AM
ForcedPerformance's Avatar
Those pics are what you get for the $95 full port job. We dont have a more expensive serivice than that.
Old Dec 8, 2008 | 09:25 AM
EvoTio's Avatar
FP, that port job looks great. I didn't see that nice port option available when I ordered my FP white. I would have definitely got that option .
Old Dec 8, 2008 | 12:08 PM
hawa's Avatar
A bit off beam(as usual), but, I have been wondering if anyone else has thought of having a Green 10.5 hotside machined out to accept the Red's turbine wheel...That is a Green compressor wheel on one end of the shaft combined with the lower backpressure, albeit higher inertia, Red turbine wheel. I'll bet that transient response would be extremely good. And it should spoolup quicker than the Red with a lot less backpressure than the Green.
Old Dec 8, 2008 | 01:28 PM
rr06rs's Avatar
I have thought of this as well and it would be nice if maybe FP would start doing an upgrade "option" for this as well. I would rather go to them first but I suppose if not, maybe Blouch, Deadbolt, or another company would do it? My only thing is, the Red uses the compressor it uses for a reason, obviously.... If not, FP simply would have stuck with machining only a larger exhaust wheel and let it be when developing. The two have to work together or sometimes performance can be hindered rather than improved. Nonetheless.....I'd LOVE to see some options like this for us Green users in the sub $600 or less upgrade area wanting more...
In the end though, I'd still like to see an option for some larger A/R's. I still believe there's gains to be had over stuffing huge wheels in tiny housings and at a much more affordable cost.
sikwititevo9
Aug 22, 2016 06:14 PM
Mitch rich
May 22, 2014 02:14 AM
midegade
15
Mar 9, 2011 06:45 PM
EvolutionEst
European Forum
Dec 11, 2008 10:16 AM
smokedmustang
10
Jun 15, 2005 01:15 PM
