coolant lines for my HTA86..
i dont want to use the stock water lines anymore, so while i have everything apart where can i get some water lines that will go onto the stock pipes.
preferably something thats a SS line, what is everyone else using that has upgraded from the stock lines?
Find the size of the tubing, and use a tube nut with an fitting on the end of it. Then you can have a -6an line running from it to the turbo.
This might help you.
http://www.jegs.com/p/JEGS/752568/10002/-1
I got my stuff from summit. Ill have to grab the part numbers when I go home tomorrow. I believe you need:
2- M14x1.5 to -6AN adapter
2- -6AN 90* SS Hose ends
6' of -6AN SS Hose
Summit Racing Part Numbers:
2- EAR-9919DFHERL
2- SUM-220687
1- SUM-230606
Summit Racing Links for parts above:
http://store.summitracing.com/partde...0&autoview=sku
Another thing is that you need to put a COPPER Crush washer between the turbo and the fitting. I just picked up a set of Oil Drain Plug washers for 14mm from AutoZone for around $3. They will prevent leaks and the copper wont rust from the oil. I could find those from Summit, but you should be able to get some that fit locally. Just make sure they are COPPER.
That should be all that you need.
I also changed the size of the thread. Its 14mm, not 10mm.
6' of -6AN SS Hose
2- EAR-9919DFHERL
2- SUM-220687
1- SUM-230606
I used these from ATP turbo with 3/8" rubber hose.
http://www.atpturbo.com/Merchant2/gr...TG-004_450.jpg
Extremepsi has lots of options also.
http://www.extremepsi.com/store/cust...cat=336&page=1
Those fittins above are for the Oil feed line I believe.
I would stick with the SS Fittings. I had Push-Lock AN hose on before and it brushed up on the turbo and it started to mealt through. Thankfully I noticed it before it mealted through, or leaked. But this time around Im going with the SS as it has a MUCH higher heat rating and wont burn through.
Ill have the Summit Racing part numbers and links up in a few minutes.
6' of -6AN SS Hose
2- EAR-9919DFHERL
2- SUM-220687
1- SUM-230606
6' of -6AN SS Hose
2- EAR-9919DFHERL
2- SUM-220687
1- SUM-230606
6 feet of line seems like a lot to me.. did you have a lot left over?
I have the same banjo-bolt style water fittings from Forced Performance.
http://store.forcedperformance.net/m..._Code=Acc-Nuts
FS[West]: STM Water Neck and Oil Return Line
evo ippo
Jan 29, 2015 06:05 AM
RJSP
Jul 2, 2012 08:07 AM
evoballer
Feb 15, 2012 06:49 AM
