it wont start? NEED HELP PLZ!
ok so i go to pick up my car after being shipped to germany i arrive at the VPC and my car wont start...the staff says is started fine just 3 days ago and now all it does is turn over n over but wont start! we used a jumper pack and still the same thing and i know im getting fuel and spark the only other thing i can think of would be shot spark plugs... im putting new ones tomarrow to see what happens. any suggestions?
Spark plugs are always the easiest and cheapest to change. They could be fouled. You should pull them to see.
You confirmed you are getting fuel and spark though. Next, you check for air. Maybe the cam timing is off or something. Maybe no compression. Who knows.
Is it making the normal cranking sounds? But it just doesn't fire up?
yeah normal cranking sound and wont fir up it is also about 30 degrees out here so that might be an issue as well i was just wondering if theres anything i should check over aswell?
RalliMark
Nov 23, 2011 06:51 PM
