DC3 Oil Catch can
Old Dec 17, 2008 | 07:12 PM
ROGERV's Avatar
Originally Posted by cfdfireman1
You have to remove the brace to drain my setup but it works very well.
I have mine mounted in the same place.
Old Dec 17, 2008 | 07:26 PM
Appauldd's Avatar
I have the small battery and mounted both right next to it. They are side by side and mounted to the tranny mount. Easy to get to, easy to drain. Like the others have said the intake mani/pvc side never has anything in it.
Old Dec 17, 2008 | 08:28 PM
Protostar1's Avatar
Originally Posted by revvin9k
No, just the AMS polished piece.
Damn, I really would like a blank one, I have no 'allegiance' to a particular company so I would just like the polished piece to dress it up. If anyone knows where to get one, I would love to hear.
Old Dec 17, 2008 | 08:29 PM
Protostar1's Avatar
Shouldn't the can be located below the line exits on the motor head so gravity can assist in the draining? I would think that position is too high. Anyway, I think below the BCS seems all around better as there is space and its pretty easy to drain.
Old Dec 18, 2008 | 01:20 AM
red evo8's Avatar
i did the diy for both pcv and intake/ vent side, cost me about 30 bucks total, air compressor filters and the same threaded clear tubing available at home depot.
Old Dec 18, 2008 | 09:55 AM
Protostar1's Avatar
Evo Style DC3 on order, thanks guys
Old Dec 18, 2008 | 10:27 AM
SPANKED's Avatar
So confused... so you really only need one drain can since the intake one never sees any oil???
Old Dec 19, 2008 | 11:38 PM
Protostar1's Avatar
I do not believe that is necessarily true... From what I have gathered, if you properly install the cans (below the level of the head and let gravity do work) both should collect something, because both lines will have blow by, however, the PVC line will have significantly more. I am not totally sure about this, but I have seen the aftermath of not using such a devise, and I have heard unequivocally that the DC3 is the best tank out there. I am installing a brand new FMIC and piping and have no desire to get it all clogged with oil. at $132 shipped, its cheap insurance.
Old Dec 20, 2008 | 05:41 AM
racer135's Avatar
Where are the connection points for the two can setup? Is there a tutorial that includes the connection points for the can. I have a one can setup that I have not install and I am trying to determine where are the correct points of connection. Right now the info I have is the one on evomoto for the 1 can install. Is that it? THis is the link for it http://evomoto.com/tech_info.php?tPa...daac1459218257
Old Dec 20, 2008 | 07:38 AM
racer135's Avatar
Originally Posted by ROGERV
I have the dual mounted on the drivers side. I would just get the single if I had to do it over again. The catch can for the valve cover/intake pipe does not collect 1 drop of oil.
This is the one that collects the oil that ends up in the lower intercooler pipe and intercooler input port. When I replace the LICP it had oil on it so it must have come from the valve cover breather to turbo inle hose. There is no other place where oil could have come from. Right?
Old Dec 21, 2008 | 07:11 AM
cfdfireman1's Avatar
Protostar you made a good choice with the DC3 and no where mine is mounted works great. You're condensing vapor into liquid so the height doesn't matter as long as it's routed right and you get a good air vapor flow through it.
Old Dec 22, 2008 | 07:22 AM
SPANKED's Avatar
So what made you go with the single style and how come you didn't get the hose and clamps for the extra $20?
You plan to install under the battery by the boost solenoid?
Old Dec 22, 2008 | 07:30 AM
SPANKED's Avatar
How does the DC3 compare to the new Buschur catch can?
Old Dec 22, 2008 | 06:36 PM
The Buschur can doesn't use any vacuum and won't pull out vapors.
Old Dec 22, 2008 | 09:00 PM
Q8_EVO's Avatar
hey whats their website, i lost all my PMS and it was there.. thanks
