Fuel pump has no power!
Old Dec 19, 2008 | 02:21 PM
Ekoy's Avatar
My evo's fuel pump doesn't get power when I turn the ignition or crank the car.
I pulled the fuel line off the fuel rail and put a bottle underneath and cranked the car. No fuel poured out.
I checked the fp fuse. It was not blown.
I pulled the pump out and tested it. The fuel pump worked.
And now I just ordered 2 fuel pump relays.
What else can I test before I take it to the shop(Im really trying to avoid)
Thanks.
Old Dec 19, 2008 | 02:27 PM
RoadSpike's Avatar
Thanks.
You check all your fuses not just the fuel pump?
Old Dec 19, 2008 | 02:38 PM
EvoDom's Avatar
cheack the fuses, wiring had the same problem on my cobra
Old Dec 19, 2008 | 03:55 PM
Johnboy1065's Avatar
sounds like you've done about all you can do so far. hopefully it's a relay
Old Dec 19, 2008 | 05:39 PM
Ekoy's Avatar
No i havent checked all the fuses. I'll go do that now.
I do have a 2000 eclipse gs. I wonder if the relays are the same. Im going to look that up. because if they are, im gonna start pulling stuff off of it.
I just bought this car for 19,000. Its black with 27000 miles. It has a hks upgraded turbo kit, wideband installed, turbo timer, and some hks ignition box. I hope the wiring work didnt mess with the rest.
The dyno sheet the seller gave me said 518 hp on race gas. And the day I drove it, it pulled really hard. I never drove anything more then 140 hp before that.
It sucks buying a car and only been able to drive it for one day. I have to wait till monday for the relays to get in. Ill keep you posted, and maby even post some pics for the fun of it.
Old Dec 20, 2008 | 01:11 PM
andreww238's Avatar
yea.. when anything goes wrong i always check every fuse first
Old Dec 20, 2008 | 01:21 PM
Spoolin18's Avatar
Check all grounds as well.
Old Dec 20, 2008 | 10:22 PM
Ekoy's Avatar
Well If all fails, I am going to turn to hardwiring my fuelpump using this guide
http://domain1886493.sites.streamlin...e/hardwire.htm
If someone would please help me understand how he hooked up the purple wire (relay signal wire) I could have my evo running tomorrow.
It runs all the way from the fuel pump to the engine compartment from my understanding. When the writer explained this step, he didnt put much detail into the whole engine compartment wiring
Last edited by Ekoy; Dec 20, 2008 at 10:24 PM. Reason: Because I edit for a Reason
sedrostyle
Lancer Troubleshooting
Oct 18, 2016 08:44 AM
stefenboy
Jan 12, 2016 08:55 PM
CNOEVO22
Dec 2, 2015 05:12 AM
han74j
Sep 23, 2014 03:37 PM
phil128
Dec 28, 2013 08:51 AM
