boost creep and service engine light
Old Dec 20, 2008 | 01:09 PM
Turbodemon's Avatar
so i was driving my car in the backwoods straightaway i floor the car in 3rd gear take off very nicely. then my car at about 4.5-5k rpms spikes up boost from 19 psi to 25 psi.
note that recently i had a 3" helix downpipe installed and the helix o2 housing.
the car felt like it hit a brick wall now the service engine light came on.
is this all releated to what might be boost creep?
Old Dec 20, 2008 | 01:10 PM
Turbodemon's Avatar
can i reset this service light myself???
Old Dec 20, 2008 | 01:34 PM
def1's Avatar
are u tuned? sounds like you overboosted and your car threw a code. unplug your battery and plug it back in might get rid of the code
Old Dec 20, 2008 | 01:38 PM
sikrsix's Avatar
Probably got P0243 "overboost" I got one once the weather cooled down and my boost rose. I take it your untuned. After my tune Ive never gotten the code again. Get a scanner to erase the code, If you plan on modding your car youll need one.
Old Dec 20, 2008 | 01:46 PM
baylorar's Avatar
yes - just get an obdII reader or a tactrix cable and laptop and you can.
i suspect a tune will fix it though
Old Dec 20, 2008 | 01:50 PM
burninrubb24's Avatar
sounds like an overboost has it happened before cause the overboost code usually requires two different times to throw the ses
Old Dec 20, 2008 | 02:29 PM
chaotichoax's Avatar
do you have a mbc or ebc?
Old Dec 20, 2008 | 05:53 PM
Turbodemon's Avatar
i am not tuned atm. i felt this happen the day after the o2 was installed i babied the car cause i had a new clutch installed now that the mileage is up i tried having fun and the overboost hit me a couple of times that i tried going fast
i have a hallman rx mbc i havnt installed yet should i make that a priority and have it tuned or is it the o2 housing??
because my buddy has he same setup as i do minus the o2 housing and he has no problems
i do live in chicago so the weather has been **** latetly is this something that affects it as well then?
thank the rest of you for the info. i will post up the code as soon as i have a day off to go to vatozone.
Old Dec 20, 2008 | 05:57 PM
install the boost controller and turn your boost down that may help the creep
getting tuned would be a great idea
Old Dec 20, 2008 | 06:08 PM
Turbodemon's Avatar
ok ill try installing it this monday hope that helps.
ty
Old Dec 20, 2008 | 08:23 PM
huevosrancheros's Avatar
Originally Posted by turbodemon
i am not tuned atm. I felt this happen the day after the o2 was installed i babied the car cause i had a new clutch installed now that the mileage is up i tried having fun and the overboost hit me a couple of times that i tried going fast
Because my buddy has he same setup as i do minus the o2 housing and he has no problems
Thank the rest of you for the info. I will post up the code as soon as i have a day off to go to vatozone.
naw son, naw son you need david buschur for this $hit!!!!
Its all about the screamer tube , psssssssshhhhhhhhheeeeewwwwww!!!
Old Dec 20, 2008 | 08:43 PM
alexlewand's Avatar
Car always has tendency to boost higher with cold weather. I had same code on my car once 243 overboost. And it feels like it hit the wall. You need to get tuned, that will fix everything. O2 housing usually has lots to do with it, cold weather and O2 and you had overboost condition, since you didn't have boost controller installed so ECU was trying to compensate. Just install MBC and get tuned. Nothing to worry about.
Old Dec 20, 2008 | 09:05 PM
great advice
Old Dec 21, 2008 | 09:47 AM
Slo_crx1's Avatar
Welcome to boost cut! The code you probably threw was for the wastegate actuator, pay it no attention...clear it and either lower the pressure via a mbc or have it tuned the right way with the cut limit raised. The delay can also be increased if you're just barely hitting past the limit, the stock setting is for 1000ms (1 sec), I'd suggest going to 2000ms or leave it at 1000ms and raise the limits a bit. Limits for a stock '03 are only around 225% (I have mine set at 305% but I regularly hit 301% load on my '03).
Old Dec 21, 2008 | 02:47 PM
czilla's Avatar
boost cut is the worst feeling feels like u broke something
