boost drop off at high rpm's?
Old Dec 22, 2008 | 09:56 PM
CantStopSpinin's Avatar
Originally Posted by BluEVOIX
Say what?
Only thing made by mitsubishi on the srt-4 is the TD-04 turbo.
yeah didnt mean the whole car. the mopar stage 3 turbo,manifold,surge valve, wastegate, and 02 housing are all made my mitsu and same as the stock set up. the emblem is on all of them lol. and the car was assembled and made in the USA in Illinois i trust mitsu to make the turbo set up more than Chrysler lol
Old Dec 22, 2008 | 11:55 PM
dsmdeliveryboy's Avatar
ummm back to the OP, I could care less about your srt-4.
Old Dec 23, 2008 | 03:14 PM
Originally Posted by CantStopSpinin
well i have an srt-4...so that isnt gonna help you. lol. but then again my car is made by
Say what?
but yet you commented on it when i said 2 words about it w.e
back to this gentlemans car
Old Dec 23, 2008 | 03:36 PM
srcevo8's Avatar
Any chance you have a slight exhaust leak or something that's minor enough to cause a drop but not big enough to really be significant?
My boost gauge is a bit generous by about 1.5psi so I spike a past 25psi which is really 23.5psi or so. After getting tuned I'm holding steady just a bit below that to readline though (ECU-based boost control w/ pill). So you might not even be hitting 18psi in reality if your gauge is as accurate as mine is. Just a thought.
So pursuing the wastegate may be a good next step. Or have a tuner take a look. I dunno.
Old Jan 16, 2009 | 04:48 AM
Gary@MellonRacing's Avatar
is the ecu boost control better than the manual boost control , to hold boost accuratley
Old Jan 16, 2009 | 05:14 AM
binky's Avatar
Sounds like you might be hitting boost cut.
You might want to connect up a Tactrix cable and use Ecuflash to check your boost limit settings. You can then adjust the table as necessary.
-Bink
evopwr187
Dec 23, 2014 06:59 AM
spikester603
14
Nov 10, 2012 10:29 PM
outsider
15
Jun 17, 2004 12:52 PM
new_B
24
Jun 2, 2004 03:48 PM
Gene
Mar 31, 2003 04:17 AM
