Deactivating the AYC??
Old Dec 22, 2008 | 03:55 AM
rolly1818's Avatar
Registered User
i know most of the Evos in the US dont have AYC but i thought i would give it a shot.
anyone know how to deactivate AYC?? so it does not have an effect when driving?
BTW its a 2006 JDM Evo IX.
Old Dec 22, 2008 | 05:57 AM
OldschoolEVO's Avatar
swap TCs
Old Dec 22, 2008 | 06:08 AM
rolly1818's Avatar
Registered User
swap TCs
there must be an easier way. i have heard of disconnecting the AYC ECU?
Old Dec 22, 2008 | 06:19 AM
yes, by pulling the fuse/relay. buy why would you want to?
Old Dec 22, 2008 | 06:24 AM
rolly1818's Avatar
Registered User
i dont like AYC, its very unpredicatble.
most track guys disable it.
how do i pull the fuse/relay?
Old Dec 22, 2008 | 04:08 PM
hytek369's Avatar
if you dont like it, sell it to us in USA
Old Dec 22, 2008 | 07:27 PM
rolly1818's Avatar
Registered User
nice one!!!
go watch reviews on it with the EVO X and u will see.
bump for help!
Old Dec 22, 2008 | 07:49 PM
jd323's Avatar
By disabling the ayc pump, you will in effect be making it an open diff.
Try lancerregister.com, they may give you a bit more insight on what to do.
Just checked this,
http://lancerregister.com/showthread...ht=ayc+disable
Old Dec 23, 2008 | 04:35 AM
rolly1818's Avatar
Registered User
Just checked this,
Thanks will have a read. currently i have the AYC pump disconnected (AYC harness from the pump).
i am not sure if this works though. will do some research. Thanks again.
Old Dec 23, 2008 | 10:01 AM
sponners's Avatar
I'm guessing you have a problem with it then???
disabling it will make it act like an open diff - which will really be
I'm sure 'track guys' would have replaced it with a rs diff or aftermarket LSD.
Old Dec 23, 2008 | 10:04 AM
Robevo RS's Avatar
Nawshad
Sep 28, 2016 01:46 PM
hatesposers
Oct 10, 2012 06:42 AM
picco97
19
May 24, 2012 01:54 AM
GsrEviluTionX
Dec 24, 2011 07:30 PM
EricLoveYouMost
Jan 11, 2008 06:25 PM
